Car wont start after fueling
NEWS
Results 1 to 7 of 7
    Jul 2011
    kearny, nj
    129
    This is weird, im having problem starting the car just after filling up my tank, this is the third time it happened to me, i have the engine light on, i want to scan it but im unable to cuz my abs module is bad, i drive a 98 passat 1.8T, Just clarified I'm only unable to start the car right after I fill my tank aftert that the car starts with no problem
    Sep 2012
    Calgary, Alberta
    71
    I've had similar issues and here's how I've stopped it
    1) Buy a a better 91 or 93 gasoline. Don't cheap out here. Shell is the only gas that works for me. No discount tony's
    2) Throw a bottle of injector cleaner in
    3) Clean your throttle bottle.
    4) Check those codes somehow.
    Super Stealth Moderator
    Jan 2003
    Waterford CT USA
    25,851
    Blog Entries
    3
    define won't start after fueling... do you mean it has a hard time starting? if so, you have a bad coolant temperature sensor.
    99 GLS, 2.8 V6, Leather, Cold Weather pkg, driven 120 miles/day, Mon-Fri
    I has a sig!
    Sep 2002
    Yorba Linda CA USA
    1,628
    This isn't likely the octane, injectors, or even the "throttle bottle". Sounds like a stuck-open purge valve.
    Jul 2011
    kearny, nj
    129
    Well i always use SUPER, the only way to start it is while turning the key hit the gas pedal making it go brum brum lol
  7. #6
    Jul 2011
    kearny, nj
    129
    But like i said i only have difficulties starting the car right after fueling after the car starts the car is fine, it starts every morning untill i visit the gas station again...
  8. #7
    Jan 2011
    San Francisco, CA
    302
    Quote Originally Posted by ylwagon View Post
    +1 on the N80. Especially if the code is P0441. See the last line here:
    16825/P0441/001089 - Ross-Tech Wiki
    (I have had an intermittent 0441 on mine so I am wallowing in P0441 land these days. FWIW, the resistance on mine is 24 Ohms.)
    You can probably avoid a hard start by not filling up until you get this scanned and fixed.
    In your case, you may be able to resurrect your evap purge valve by soaking it in some carb cleaner to remove whatever deposits prevent it from closing.
    EDIT: you can remove the ABS module and go ahead and scan it for codes that way. Your breaks will still work, you just won't have ABS.
    Last edited by GLInick; 02-04-2013 at 04:06 PM. Reason: how to bypass ABS blocking code scan.
  9. Remove Advertisements
