Originally Posted by
Mister T
Also, if you want to prevent your manifold from cracking, just make an L shaped or similar bracket that can brace the manifold to the head. There's a bolt hole for a bracket that holds the stock oil line just above the manifold collector, use that.
I had a $90 ebay manifold that I got ceramic coated and braced in addition to cutting stress relief cuts in the manifold flange and the thing never cracked. More than I can say for my two $350 034 'quality' POS manifolds (one cracked after less than 3 months).
Also, using a high flow manifold on a K04-015 is a waste of time and money IMO. I had one installed with my K04-015 setup and it didn't do anything in terms of peak power as far as I could tell, it just made the torque onset a little less sharp.
If you still want to free up some flow capacity on the K04-015 I would advise doing a good port and polish on the stock manifold. The narrow runner design on it keeps the exhaust gas velocity high and it'll spool faster and as far as I'm concerned will flow more than enough for a K04-015.
Where you may want to move to the high flow manifold is on something like a Frankenturbo, or GT28 and larger. Just remember, with a K03 or K04-015, the turbine housing is the bottleneck, not the exhaust manifold.
My personal advice if you want to make some more power on your current setup whatever it may be is to get a Water/Methanol injection kit for what you would be spending on a manifold. K03s and K04s really start heating up the charge air, especially since people are usually squeezing everything they can out of them due to their relatively small size. Getting that air charge cool and keeping your timing as high as you can will net you some noticeable gains and protect your engine all at the same time.
