Car jerks on shifting
NEWS
Results 1 to 11 of 11
    Oct 2011
    Williamsville
    65
    I have a B5 2000 1.8T passat and i recently got the oil changed from my auto repair guy. That dumb ass put Semi-Synthetic instead of full synthetic, I got it changed and put full synthetic. the car jerks every time i shift from N to D, what could be the problem in this case. Help is much appreciated. !
    4th Gear
    Sep 2002
    Yorba Linda CA USA
    2,683
    Are you thinking the two things are related? I can't tell you why your car jerks, but there is a sure way to keep dumb ass repair guys from putting in oil that you don't want: DIY.
    Oct 2011
    Williamsville
    65
    No I don't think that the two things are related, but I was wondering what could cause it; may be he didn't plug something in ?
    Jul 2008
    Chicago
    51
    14,389
    Try cleaning your MAF. The Tiptronic system looks at MAF data when making decisions about how to make shifts happen.
    Did he also change the air filter? If so, check the MAF connector. Get it scanned for codes. Is the idle unusually high? Was the oil level overfilled beyond the full mark?
    4th Gear
    Oct 2008
    Raleigh, NC
    37
    2,541
    Did the jerking happen only after, or before as well? I had issues once when air filter was changed and MAF was disconnected or broken, then car began jerking when shifting into R and D to and from P and N. They replaced MAF and all was well.
    Sent from my DROID2 using AutoGuide.Com Free App
  7. #6
    Oct 2011
    Williamsville
    65
    @ Steve in chicago and @nolesfan
    I will take a look a at the MAF. Is there a DIY or set of pictures that will point me in the right direction.
    and @ nolesfan the problem is exactly as you have described,
    Thanks,
  8. #7
    4th Gear
    Aug 2006
    Halifax, NS
    41
    4,235
    Semi-synthetic wasn't a total deal-killer. You probably could have run it until the next change with no issues. If this jerking happened right after the oil change was done, you might want to check your transmission fluid. A common mistake is thinking the drain for the tranny is the oil drain plug...
  9. #8
    4th Gear
    Sep 2002
    Yorba Linda CA USA
    2,683
    Quote Originally Posted by Troy Jollimore View Post
    But a totally drained trans won't even drive, let alone "jerk".
  10. #9
    Jul 2008
    Chicago
    51
    14,389
    They may have pulled the trans plug and lost a quart before realizing what was going on and plugging it back up. "Hey... that's not oil!" Stranger things have happened. Troys suggestion to check the trans fluid level is worth following up.
  11. #10
    Sep 2010
    Clinton, OH
    44
    Quote Originally Posted by rokzin View Post
    Did you're auto repair guy pay for the replacement oil or did you go somewhere else?
    Perhaps someone nearby has a vag scanner?
    Last edited by wadia; 06-19-2012 at 12:55 AM. Reason: retracted - car is a 1.8 - not an ATQ
  12. #11
    Oct 2011
    Williamsville
    65
    Solution : Fuse #34 was blown . Now it shifts absolutely fine .
    Holy God!
    Thanks
  13. Remove Advertisements
