Wheel bearing cost for labor??
NEWS
Results 1 to 15 of 15
    Apr 2010
    Allentown Pa
    100
    Hey guys,
    My passenger side wheel bearing needs to be replaced so i'm going to replace both the fronts. I'm looking to pickup the wheel bearing kit for $39 from autohausaz.com.
    How much did it cost you guys to have them installed in your area? Monroe muffler want to charge $381 to have them installed
    Is that price normal for labor?
    4th Gear
    Oct 2009
    Toms River NJ
    3,233
    I wouldn't be surprised if they wanted to charge you 2-3 hours a side for each bearing. 6 hours at $70/hr labor (maybe by you, labor rates are higher around my area) sounds reasonable to me since they can be a PITA especially if they have to fight siezed up suspension bolts.
    I only have eyes for Princess Alisa
    Jan 2009
    610-Whitehall,PA
    35
    2,557
    Whitehall auto charges $45 to press bearings in take your hub to them that's the cheapest way to do it
    Apr 2010
    Allentown Pa
    100
    Quote Originally Posted by gpassat03 View Post
    My man, next time I'm going hit you up first for advice before posting. Thanks E.
    Jan 2009
    610-Whitehall,PA
    35
    2,557
    Quote Originally Posted by g2storm View Post
    Anytime man give them a call
    http://www.google.com/url?sa=t&rct=j...D--tQV3nF_nj_w
  7. #6
    Jun 2011
    Rhode Island
    27
    387
    You know you are going to have to take your spindles off and bring it too them right?
  8. #7
    Apr 2010
    Allentown Pa
    100
    @ Gpassat03 and Resonnatorr
    Is there a DIY write up on removing the spindle and if i'm going to remove the spindle, should i just wait until i do the contol arms and do them at the same time?
  9. #8
    Jul 2009
    Hyde Park, VT
    217
    The spindle is the junction of all the control arms. You will want to do it all at once. There are many write ups here about CA replacement. Removing the spindle is just one more step in removing the axle nut and abs sensor. Tie rod has to be disconnected as well, so you might need a new set of outer tie rod ends too.
  10. #9
    Apr 2010
    Allentown Pa
    100
    Quote Originally Posted by stealth View Post
    I'm looking to get the control arm set that includes the tie rod ends. I'm going to follow the DIY below to get the control arms done but i'm not sure how to remove the spindle. Is there a DIY on removing the spindle? I looked and was unable to find anything.
    PINCH BOLT REMOVAL made easy - pics
    Upper Control Arm - Tie Rod End R & R w/pics ...
  11. #10
    Jul 2009
    Hyde Park, VT
    217
    Might be some confusion on terminology here.
    I was allowing " spindle" to pass uncorrected, but it would be more correct to call this part a knuckle. I think VW calls it "wheel bearing housing". It's the big cast part that all the outboard ends of the CAs connect to, where the pinch bolt resides. Once the CAs are removed, just the TRE, abs sensor, and axle retaining bolt remain. See write ups on axle removal for that.
    You could call the hub a sort of "removable spindle".
    Keep in mind there are 2 diff size bearings depending on year/engine.
  12. #11
    Apr 2010
    Allentown Pa
    100
    Would this writeup do the trick?
    DIY: Steering Knuckle Removal/Installation
  13. #12
    Dec 2009
    Aurora,IL
    11
    Blog Entries
    2
    I brought my awd passat to a local specialty shop that said that they would replace the front bearings for $350, parts included. They had my car for a day, called me and said they could not get the hubs off...wanted more $$$. Took it to Pugi vw dealer in downers grove,il, they did it for $770 with a loaner. Replacing the bearings was the BEST investment ever, car now rides like a dream.
  14. #13
    Jul 2008
    Astoria, NY
    34
    1,235
    i had my bearings done a few months ago. took it to a trusted indie shop here in nyc. i provided the parts and my pinch bolts were not an issue, as i have done other suspension work recently. i think the job took about 3 hours and the labor charge was around $250.
  15. #14
    2nd Gear
    May 2008
    New Hampshire
    731
    One quick warning -- if you have a very high mileage Passat, you might find that the ABS sensors have rusted into the spindle. Don't bother taking them off, you can pull out the wire that goes into the upper part of the fender (there is a rubber grommet that it goes through) and you'll find a connector that you can detach. Just take the entire spindle with sensor attached to the machine shop and $25 a side later you can have your new bearings pressed into the hubs. I managed to get one ABS sensor out by completely destroying it, so I didn't remove the sensore on the other side and it worked out fine. The new ABS sensor was more expensive than the wheel bearings, but live and learn...
  16. #15
    Apr 2010
    Allentown Pa
    100
    Quote Originally Posted by fritznh View Post
    Great advice thanks a lot because i was going to attempt to remove the ABS sensor before taking it to the shop
  17. Remove Advertisements
There are currently 3 users browsing this thread. (0 members and 3 guests)
