O2 Sensor Differences?
NEWS
Results 1 to 3 of 3
    Apr 2009
    Montreal, Canada
    1,620
    Hey guys
    Need to change my pre-cat O2 sensor.
    I think I might be able to get a post-cat sensor for cheap...so what's the difference between the two? Is it just the wire lengths? Looking on ECS, it seems the post-cat sensor's wire is a lot shorter? I thought it would have been the longer one?
    Am I right in saying that if I buy the rear sensor, I can splice it into the wiring for the front sensor and have it work like new again? Basically just like installing a universal sensor?
    Part # that I can get is: 06C-906-265.
    It says that the sensor is for all engines except AEB and has been superseded by a new sensor...so what's the difference? Can I still use this sensor on an AEB? I thought all the sensors were the same?
    Thanks,
    Elliott
    Apr 2009
    Montreal, Canada
    1,620
    Bump
    4th Gear
    Sep 2002
    Yorba Linda CA USA
    2,866
    Don't know for sure but autohausaz lists the same Bosch universal 4-wire heated sensors for both front and rear-so maybe your's will work OK.
  5. Remove Advertisements
