P0171 Lean Code Help
NEWS
Results 1 to 10 of 10
    Sep 2009
    new orleans
    152
    I posted this picture I took yesterday in another post I did about a rattling sound while acccelerating. Could these small holes in the plastic piece be causing the Lean Code? I would think it would be something more. What is this piece called? Air intake? Thanks Joebobphoto.jpg
    Confused
    Dec 2002
    State of Confusion
    4
    3,525
    That can certainly cause a lean code. The ECU is getting more air than expected and this could be the root cause. I think that part is called the snorkel. Good luck!
    May 2006
    Abingdon, MD
    37
    20,230
    That will cause no lean code at all, actually. That piece is commonly referred to as an air intake snorkel coming from the grill to the opening of the airbox. All pre-MAF. Lean codes are a result of a leak AFTER the MAF sensor. Look around the engine bay for small diameter hoses and check for leaks.
    Update your profile please, or at least give us some vehicle information. Year, engine, trans type. There are three major places to look. Assuming 1.8T. There is an inverted L shaped Home Page > Search > Suction > ES#5939 Breather Hose - 06B133783AT hose leading down the side of the intake manifold to a Home Page > Search > Suction > ES#1884320 Suction Pump - 058133753D Suction jet pump.
    Both the hose and pump are prone to failure. Also a PCV valve that leads from just behind the throttle body to under the intake. Both the L hose and the PCV hose are right next to each other on the intake manifold. Listen for hissing while the engine is running and then clamp one hose shut at a time and see if the sound changes or idle changes.
    Nov 2009
    Vancouver
    41
    When I had P0171, someone suggested to use a spray water bottle (fine mist) along the vacuum lines and listen to engine idling rpm change. That's how I discovered one of the OEM vacuum tubes cracked at the connector (stress fatigue due to bend). I taped the broken section and the code went away after a while. I then proceeded to replace all 4 hoses with non-OEM ones. It has been 4 years and no P0171 code since.
    Sep 2009
    new orleans
    152
    Good advice. I put some duct tape today over those holes on the snorkel and no difference.The car is very sluggish when accelerating sometimes. Noticing bad gas mileage too I believe.
  7. #6
    4th Gear
    Oct 2004
    Encinitas CA
    4,449
    Of my four OEM 3.5mm vacuum lines, all but the super-short one to the fuel pressure regulator have failed. I was getting periodic P0171 codes until I replaced the diverter valve and its control hose (the last of the 4 to go). My O2 sensor finally went, as well.
    Now, with a new O2 sensor, new L hose, new F hose (both had holes), diverter valve, and 3.5mm vacuum lines, I occasionally get a P0172 (too rich) code, which I ***think*** (comments invited!) might be caused by a leak somewhere in the boost circuit. I really do need to get a VAG-COM.
  8. #7
    Jul 2008
    Chicago
    51
    14,344
    X2 everything VAGguy wrote.
  9. #8
    Jul 2011
    boston
    4
    I got same code 4 months ago, and was focusing on maf, front O2 sensor and vacuum leak. I replaced o2 sensor and cleaned maf, didn't worked out. But ended up to replace a bad check valve located on the top of air box, no more faulty code.
  10. #9
    Dec 2008
    Dallas, TX
    1,209
    Battling this myself atm: CEL, codes P0303 and P1136 - diagnosis?
    Pls update thread if you find anything. Very annoying, think I might try the spray bottle (instead of building smoke tester)...might just swap out L hose and connected pump for good measure, that seems to be the most common prob outside of vac lines (which appear OK). Check valves all look OK, by which I mean there's no play on either end like previous ones that busted.
  11. #10
    Apr 2010
    Maryland (D.C. Area)
    21
    1,775
    I just found a leak where a brake booster L hose comes to a T with two other same-material hoses. (The material that these hoses are made of are very odd lol) Until I can get those hoses and the T, I've just put sealant on it which may or may not hold up, but we'll see. It's causing me a bad idle and a P0171 Lean.
    I found it with carb cleaner, water from a spray bottle didn't do anything for me, the motor only bogged down with carb cleaner. But, I heard a very quiet hiss coming from that area, and fiddled around until I felt the leak on that T. Looks like a pain to replace those too.
  12. Remove Advertisements
