Won't rev past 1200 RPM after battery died.
NEWS
Results 1 to 7 of 7
    Feb 2011
    Colorado
    26
    1999 1.8T Passat Wagon
    I left my lights on yesterday and killed my battery. Unfortunately I ended up having to buy a new battery.
    Now, it seems to idle much lower than normal and when I went to just drive it around the parking lot it would only rev up to about 1200 RPM then it suddenly drops in RPM very quickly. After messing with it a little bit I am getting a check engine light but I need to get my code reader out of storage so I can retrieve the trouble code.
    It is just really odd because it was running great up until I killed the battery. I read another thread that the computer needs some time to "re-learn" but I am just not sure about this.
    Jul 2008
    Chicago
    51
    14,391
    The throttle body and engine computer may have lost calibration with each other.
    Throttle Body Alignment (TBA) - Ross-Tech Wiki)
    2nd Gear
    May 2011
    Ardmore, PA
    649
    Pretty sure your car went into limp mode. You probably shorted something out when jump starting it.
    4th Gear
    Apr 2007
    Greensboro, NC
    3,158
    x2, ^this^ Find someone with a VAGCOM and it will take less than 5 minutes to fix.
    2nd Gear
    Dec 2004
    Gateshead, UK
    41
    910
    ....see if the bonnet up, door open, key turned for 5 mins trick works as well?
  7. #6
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    51
    21,834
    Not very well on the 98-99 DBC engines.
  8. #7
    Feb 2011
    Colorado
    26
    Ended up having to take it to the mechanic to have them adjust the Throttle Body. They ended up cleaning it and reprogramming it and that ended up fixing it.
    "Door Open, Hood Up, Key" trick didn't work at all.
  9. Remove Advertisements
