Real slow on acceleration! How can I fix this?
NEWS
Results 1 to 10 of 10
    Jul 2011
    Silverton, OR
    33
    I have a 1998 Passat 1.8T 20V and my acceleration is real bad, like it acts like it wants to go... but it doesn't at first, than picks up! I don't like that. What can I do to fix this so I can get a good acceleration.
    THANKS!
    May 2006
    Abingdon, MD
    37
    20,440
    Have you ever driven a turbo car before? Has it always been like that? Sounds like normal turbo.lag to me...
    Jul 2011
    Silverton, OR
    33
    No, I haven't driven one before. I had a Jeep before my B5. Is there anything I can do to change that? So it's normal?
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    59
    10,115
    Have someone who knows the Passat 1.8T drive your car and see if it's behaving right. You could be experiencing normal turbo lag; until it spools up, you have a little 1.8L engine trying to drag a 3300 lb. car. Not much you can do about it.
    Jul 2011
    Silverton, OR
    33
    Ugh. okay Thanks Scott!
  7. #6
    Jan 2011
    Montyshire, PA
    299
    i agree with the turbo lag thing but also mind petrols a fairly gutless down low in the revs
  8. #7
    2nd Gear
    May 2002
    Portland OR USA
    808
    Hook up a vacuum / boost gauge to see what kind of boost you're getting now.
    If you really want to feel some power you will need to budget for a chip and exhaust upgrade.
  9. #8
    Aug 2011
    florida
    168
    Mmmmm turbo lag
  10. #9
    Jul 2011
    Silverton, OR
    33
    TJ (TurboJim), Where can I buy a decent/cheap Exhaust Upgrade??
  11. #10
    2nd Gear
    May 2002
    Portland OR USA
    808
    The problem you run into when upgrading to a 2 1/2" or 3" high-flow exhaust system is drone. The least expensive system will be one you build yourself - DIY Budget "Cat Back" Exhaust
  12. Remove Advertisements
