Door microswitch repair - have you tried it?
NEWS
Results 1 to 12 of 12
    Dec 2006
    SE Michigan
    361
    My driver's side door has exhibited intermittent problems with the microswitch for over a year - sometimes the door won't lock unless I lock, unlock and re-lock it. Just the other day, it also stopped turning on the interior dome light when open. So I've likely got two separate problems with the unit.
    I've seen the write-up for disassembling, inspecting and re-soldering the joints on the switch unit, but with 220K+ miles on my Passat I'm wondering if it will be worth the trouble to do this, considering that I might break something on the door during disassembly.
    Can anybody who has tried this repair let me know if you were (or were not) able to successfully repair the unit by touching up the solder joints? I'd like to see what my chances are before investing the time.
    Thanks.
    Jul 2010
    Forest Lake, MN
    169
    Its not too difficult to get into there. On tdiclub they have a guide for the MK4 which includes using a switch from radioshack.
    Jon
    Feb 2010
    Southern VT
    190
    Well, I've tried it and had success. I'm working my way around the doors, and have done this to 3/4 of them so far. Among other issues within the door or module, I have found the cracked solder joints. Re-soldering them and cleaning up the insides of the door latch housing has made some non-working aspects of my door(s) begin to work again. Check the traces on the little circuit board with the solder connections while you're in there -- some of mine had been corroded away. In my limited experience with these door modules I have not yet come across a micro-switch that is actually broken, they appear to be pretty tough.
    The drivers door wasn't too difficult for me to dismantle and reassemble.
    Give it a try, and good luck!
    May 2010
    Nampshire
    1,114
    I have yet to attempt this project mainly because I don't think I have a soldering tool to correct the cracked joints. But the main reason why I am not tackling this asap is because my door still locks, but the interior lights wont acknowledge the door being open. (passenger door)
    Jul 2008
    Chicago
    51
    14,586
    I used this writeup and it told me everything I needed to get the job done.
    taligentx.com: Passat - Door Lock Mechanism Repair
    My drivers side rear door went from locking when it felt like it to locking every single time. It's been a few years since I did that repair and it's still working 100% of the time.
  7. #6
    Sep 2006
    Rio de Janeiro, Brazil
    32
    433
    I'm sorry for stealing your thread with this question but a couple of years ago I got the same issue on my 99 AEB.
    After dismounting the whole door loock mechanism I found that all the solders joints were cracked and had them all rebuilt by an electronic technician guy (I'm not very lucky with soldering) who fixes TV sets around here.
    The thing is that after puting everything back together, now everytime I hit 20 MPH I hear the door lock "relocking" itself as if it didn't realize the door was already locked. I reopened the whole thing and took the circuit to that guy; we tested all the solders and the circuit with a voltimeter and everything seems to be fine.
    I'm suspecting that this is related somehow to the inside steel cables which got a little "stretched" during the removal; maybe now, since they are a little stretched, they just don't let the interior latches of the mechanism return to their exact locking position with makes the system unable to realize when the door is locked or not.
    Before ordering new cables, you think my theory is plausible or does this malfunction necessarily have to be related to the circuit / solders ?
    Thanks a lot!
  8. #7
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    59
    10,049
    Quote Originally Posted by VitorBart View Post
    Having diddled with the cables a bit, I'm guessing no. I think one of your switches is bad.
  9. #8
    Jul 2008
    Chicago
    51
    14,586
    Quote Originally Posted by scotts13 View Post
    X2
    The switch that reports the door being locked (or unlocked) is not providing the proper data. The CCM thinks it's open when it's locked. It may be the switch, the traces on the board for that circuit or the mechanical part that physically pushes on the switch.
  10. #9
    2nd Gear
    Oct 2007
    US
    928
    Yep, I did it on my rear door, and wrote up a DIY specifically for the rear door (it is a little different than the front door). It borrows mostly from taligentx. I will find the DIY in the info forum and post a link.
    It took me a long day to complete this, but I was being ridiculously cautious not to mess anything up. Not to mention I hit some road blocks that took time to resolve - like the window dowel. And, I was taking my time to document for the DIY.
    Here is the link:
    DIY Rear Door Disassembly and Lock Mechanism Repair (for Intermittent Lock)
  11. #10
    Jun 2008
    King of Prussia Pa
    162
    Question
    Does anybody know if the dome light and the step/courtesy light are linked by the same micro switch? I may just have a burned out step/courtesy light bulb (drivers door) but I am curious. I do however have the problem of my dome light not turning on when the drivers door is opened but I am wondering if these problems are linked.
  12. #11
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    59
    10,049
    Quote Originally Posted by sliver108 View Post
    Yes, one switch (in the module) that informs the whole system.
  13. #12
    Jun 2008
    King of Prussia Pa
    162
    So my step light would not work no matter what huh.
  14. Remove Advertisements
