b5.5 AWM vacuum diagram.
NEWS
Results 1 to 7 of 7
    Bes
    Bes is offline
    Dec 2010
    canada
    30
    anyone got a diagram of the vacum lines for 2002 1.8T AWM. I've looked around cant find one.
    Dec 2002
    Maplewood, NJ
    155
    I think they're a little bit different for each year, and was never able to locate one that was exactly the same as my 2002 AWM.
    Apr 2010
    BZN, MT
    273
    [IMG][/IMG]
    Apr 2010
    BZN, MT
    273
    [IMG][/IMG]
    Dec 2002
    Maplewood, NJ
    155
    different from my 2002
    Neither of these are quite the same as my 2002 1.8T, the location of the suction pump is actually behind the engine, above and a bit to the right of the temp sender. The puck is located at a different place too. I saw a 2003 1.8T AWM and it had a very different setup.
  7. #6
    Oct 2008
    Rockland NY
    154
    straight from etka...you are correct...2002 and 2003 have slightly different configurations.
    somewhere under the hood on my 2003 there is a sticker with a schematic diagram of the intake and vacuum system. can't remember exactly where...but its somewhere you can readily see like the underside of the hood or on the top of the radiator support.
    what are you trying to do? basic setup is the same...4 lines:
    intake mani to dv
    intake mani to fpr
    N249 to intake mani
    N249 to combi valve
    http://www.passatworld.com/forums/sh....php?p=2265055
  8. #7
    Oct 2010
    PITTSBURGH!
    20
    I'm just trying to see where this mysterious shredded vacuum line goes,, and maybe it'll turn my cel off.. I ran it from the farthest to the rear nipple thats under the manifold to the combi,,, because the hose looked like thats the direction it was headed and it seemed to reach, and they were both empty nipples.. and the remnants of the hose that was still on the nipple looked like it was the same diameter hose line and same breed...
  9. Remove Advertisements
