Heated Seat repair
NEWS
Results 1 to 11 of 11
    Jul 2010
    scranton pa
    91
    Heated Seat repair
    So I am the new owner of a '04 W8 6spd. It had a few problems ( ABS mod, new rotors, and every once and a while it tells me to check my brand new brake pads ( yes they have the sensor.)) But now that its gotten cold in Pa my wife has noticed that the passanger side heated seat does not work. I did some research first on here and w8forum.dk but everything I find is about the seat buring a hole through the eather, which is not the case. It has been suggested that it is the "switch" but does that me the switch in the dash or some part under or in the seat? In either case does any one have a part number so I can shop around.
    6th Gear
    Feb 2007
    Lehigh County, Pa.
    59
    9,330
    It's usually the switch in the dash. Should be part number 3B0 963 564 C. But first, call the dealer with your VIN number to see if you're covered by a recall - there was at least one for heated seat issues. It's usually, as you say, for overheating - but you never know.
    4th Gear
    Dec 2008
    Hungary
    2,513
    Neither of the heating elements on the seat (seat back and seat bottom) are working?
    Check fuse number 44. I'm not sure if the dash switches for the right and left side are interchangeable, as far as the connectors, but I would check to see if you can switch them to check the faulty side.
    If the elements inside the seat are fried you can always check a salvage yard.
    Good luck.
    Jul 2010
    scranton pa
    91
    the dealer
    I did take the car to the dealer when I purchased it for a state inspection and any recall work. They did change the coils but mentioned nothing about a heated seat. Is that something they would only repair if it was broken or would they just replace the part?
    Jul 2010
    scranton pa
    91
    Quote Originally Posted by hu vw View Post
    Good luck.
    Is that fuse only for the passanger side or both driver and passanger. The driver side works great although it heats slower than my volvo did?
  7. #6
    4th Gear
    Dec 2008
    Hungary
    2,513
    Considering the term, "Stealership" I would contact the dealership and ask specifically if the recall applies to your vehicle and if records shown if it was done if applicable.
    Looking through the digital version of Bentley there is a recall for 2002-2003 passenger side seat heater switches. I didn't see anything about MY2004 but the dealer will be able to tell by your VIN.
    Good luck.
  8. #7
    4th Gear
    Dec 2008
    Hungary
    2,513
    Forget the fuse, it is for both. Sorry, I didn't pay attention.
  9. #8
    Jul 2010
    scranton pa
    91
    Good luck.
    Thanks for the help, anything in the manual about the fuse, is it both driver and passanger or is fuse 44 jsut the passanger side?
  10. #9
    Jul 2010
    scranton pa
    91
    I saw your message after I posted my own, I'll give the dealer a call but I have an idea that l know the outcome already. I was able to locate a used switch fairly cheap ( $32 shipped) so that will likely be my solution. Thanks for every ones help.
  11. #10
    Aug 2010
    Iowa
    137
    Quote Originally Posted by mperew8 View Post
    I had the same problem, drives side worked fine passengers did not heat up at all. The easiest check is to pull the drivers side switch and swap it with the passengers, all you need are some needle nose pliers and a screwdriver. Your going to have to do this anyway to install the new switch, this just eliminates it as a possibility for certain.
  12. #11
    Jul 2010
    scranton pa
    91
    Quote Originally Posted by RCook View Post
    Great idea! Is there a DIY any where that you know of on this, just so I can do it with out messing up the dash plastic.
  13. Remove Advertisements
