How to take passenger door panel off
NEWS
Results 1 to 8 of 8
    Nov 2010
    3
    Ok sorry if this has been asked..I am still new and adjusting to this site...
    Anyhow recently my window on the passenger side came off the track so I guess I will have to take off the door panel in order to fix that..Can anyone tell me if there is guide on how to do this without damaging the door panel and the difficulty level..Thanks
    I am just debating whether to do myself or pay a shop over an hours worth of labour to do..
    Much thanks
    6th Gear
    Feb 2007
    Lehigh County, Pa.
    58
    7,738
    Way easy. Mostly a few Torx screws in the bottom edge, then clips around the perimeter; I simply use a butter knife to pop them off. BUT, you first have to loosen the pull handle, which is screwed on from both sides of the panel. You pry loose the trim insert in the handle (carefully) then remove the two large screws inside.
    Once the panel is "loose" you still have to be careful of the electrical leads to the switches and the puddle lights; and the cable to the door lock. The cable is tricky to get back on correctly, so note carefully how it attached before you remove it.
    I took 15 minutes the first time I removed the panel, and I'm slow and careful.
    Nov 2010
    3
    Ok thanks I will check that out...Is there a special type of screwdriver to use or a philips/flat should suffice?
    6th Gear
    Feb 2007
    Lehigh County, Pa.
    58
    7,738
    Quote Originally Posted by mukan24 View Post
    As stated, they're Torx (T15, I think), so you'll need one of those. Matter of fact, if you're going to be doing much work on the car, you should pick up a set.
    Jul 2010
    Central NJ
    488
    i dont know about fixing the window but i happen to take my pannels off a lot and ive gotten it down to about 5 minutes to take the pannel off.
  7. #6
    Apr 2009
    Montreal, Canada
    1,619
    http://www.taligentx.com/passat/main...lockmechanism/
    That's a pretty good guide to taking the panel off!
    Driver's side but same idea...
  8. #7
    Jul 2010
    Central NJ
    488
    make sure you get the screws behind the door handle. it can be a pain to get the cover off the door handle to get to them
  9. #8
    Mar 2004
    Finland
    358
    Quote Originally Posted by nkausch View Post
    The door handle trim was very tight in my car. I lost faith it can be removed without breaking it and just pried it until it suddenly popped out, it didn't break. There are two metal clip fasteners behind the trim. I used a plastic window scrape as a support for flat head screwdriver to pry under the trim.
  10. Remove Advertisements
