Trying to find P/N for bigger oil filter for 1.8T
NEWS
Results 1 to 25 of 25
    2nd Gear
    Nov 2001
    San Diego CA USA
    550
    As the title says I am trying to find the part number for the newer, larger oil filter for a 1.8T motor. I spent 10 minutes trying to find it with the search function with no luck. Can someone help me out here with a part number? Looking for a Bosch number if possible.
    Feb 2010
    14
    068 115 561B OEM part number
    Bosch: B72174
    Mahle: OC-51
    Mann: 940/25
    I only use Mahle or Mann.
    Oct 2009
    Vermont
    40
    241
    Also good:
    Wix 51191
    Purolator L30257
    Forum Sponsor
    Dec 2006
    Wadsworth, OH
    2,838
    Part numbers can be seen here on the website as well:
    http://www.ecstuning.com/Volkswagen-...aign=postreply
    2nd Gear
    May 2002
    Portland OR USA
    802
    Purolator L40316, Wix 51333 / Napa Gold 1333. These are the filter sizes sometimes referred to as the Big Kahuna.
  7. #6
    4th Gear
    Aug 2006
    Halifax, NS
    41
    4,235
    I just did mine and asked the local parts shop for their equivilent to the 51333, and they gave me a filter that was about 2/3 the size of the Napa Gold 1333 'Big Kahuna'. I was a bit disappointed, but at a cost of $5 vs. $40 for the Napa? I'll stick with it.
  8. #7
    2nd Gear
    Nov 2001
    San Diego CA USA
    550
    Quote Originally Posted by VT Variant View Post
    Wix 51191
    Quote Originally Posted by TurboJim View Post
    Wix 51333
    Seems to be a little confusion here. Is one of these the "Standard" and one the "Big Kahuna"?
    Quote Originally Posted by Troy Jollimore View Post
    Sounds like they gave you the original "standard" size. This is what I am trying to avoid.
  9. #8
    2nd Gear
    Jul 2003
    Calgary, Alberta
    43
    740
    I used to be able to get the 1333 at the local NAPA Autoparts, but not any longer - this thing is the big kahuna. The 1191 is the next size down. The 1333 was always $18, while the 1191 I got last week was $8.
    John
  10. #9
    BSK
    BSK is offline
    Dec 2009
    nova
    233
    old ford f250's use the same filter as well
  11. #10
    Oct 2009
    Vermont
    40
    241
    Quote Originally Posted by D-n-Tyke View Post
    Wix 51393 is the 'standard' size used prior to 2004.
    Wix 51191/Purolator L30257 is the revised 'larger' size used 2004+ and supercedes 51393
    Wix 51333/Purolator L40316 is the Big Kahuna
  12. #11
    2nd Gear
    Nov 2001
    San Diego CA USA
    550
    Thanks for clearing that up VT.
  13. #12
    Sep 2009
    The Yoc, CA
    102
    i use mobil's oil filter.. is that bad?
  14. #13
    Oct 2009
    Vermont
    40
    241
    The Mobil 1 M1-301 and K&N HP-3001 filters spec'd for the 1.8t have a much lower bypass valve setting. There is much to debate, but I personally won't use them.
    See this thread and draw your own conclusions.
  15. #14
    2nd Gear
    May 2002
    Portland OR USA
    802
    Champion Laboratories ( http://www.champlabs.com/ ) is the North American supplier of oil filters to VW. Questions about their products can be address to their technical hot line. They have a 800 number, or you can send them an email. They don't make a "Big Kahuna" size filter equivalent to what is offered by Purolator or Wix.
  16. #15
    4th Gear
    Aug 2006
    Halifax, NS
    41
    4,235
    Tyke, nah...It was more the size of the VW 'upgrade' filter size. The 1333 Big Kahuna is GIGANTIC, almost a foot long...
  17. #16
    2nd Gear
    Sep 2010
    313
    711
    is the point of this larger filter to capture sludge? or just to increase oil capacity?
  18. #17
    2nd Gear
    Jul 2003
    Calgary, Alberta
    43
    740
    Its just a way to increase oil capacity, reducing heat load damage by spreading it around more oil. Theory was that the VW sump was too small for a turbocharged engine, hence the need for VW approved oils and slightly more capacity with the 1191 filter (and by extension, the 1333, which was not selected by VW).
    John
  19. #18
    2nd Gear
    May 2002
    Portland OR USA
    802
    Quote Originally Posted by euroblood View Post
    To prevent sludge by having a larger oil capacity. Sludge doesn't normally show up in a oil filter unless you've introduced something like ARX, MMO, Kreen, etc., into the oil to remove it.
  20. #19
    Jul 2010
    Alberta, Canada
    16
    good to know, thanks john
  21. #20
    May 2012
    Fburg VA
    39
    Oc51 from partsbin.com are under 5 bucks and shipping isn't bad.
  22. #21
    2nd Gear
    Apr 2011
    NJ ALL DAY
    829
    got mine for esctuning. Larger filter and OEM oil
  23. #22
    Forum Sponsor
    Dec 2006
    Wadsworth, OH
    2,838
    Quote Originally Posted by bigbea View Post
    Thanks for the order!
  24. #23
    May 2012
    Fburg VA
    39
    Also advance auto parts now carries Mann filters... Already larger size filter and is 5.80 and in stock... No shipping pick it up and done
  25. #24
    Jul 2012
    United Kingdom
    43
    Why you want fit bigger filter? Do you know that oil filter is match with oil pump, oil amount, oil pressure and milage from fitting to change filter?
  26. #25
    2nd Gear
    May 2002
    Portland OR USA
    802
    Quote Originally Posted by Sebastian TDI View Post
    Having a larger oil filter allows for more oil in the system. This, at least in theory, should reduce the risk for sludge in the 1.8T. VW specifies a rather high pressure relief valve for it's oil filters. Using one with a lower setting would mean that if the filter were to go into by-pass more oil would pass through unfiltered. A filter doesn't often go into by-pass.
  27. Remove Advertisements
