Interchangeable key fobs?
NEWS
Results 1 to 15 of 15
    Jun 2006
    22
    Does anybody know if key fobs are interchangeable between models? My key fob electronics got hosed after a swimming pool accident. I've tried changing the battery and reprogramming to no avail. Somebody on craigslist has VW fobs for sale and i just want to attach it to my key and program the enw fob. Does the fob have to be from another passat, or is it okay if it is from a beetle, tourag, etc.... I have a 1999 B5 GLS.
    Thanks in advance!
    NC
    Sep 2007
    Central Washington
    282
    When I had our 01' I bought a couple spare keys/fobs- and I was able to make the remote work on BOTH my 00' GTI and our B5 passat (at the same time no less- it unlocked both cars, confusing, but sometimes handy!). I kept one around and later used it on our 99' A6.
    From my experience you've got a very good chance of it working at least for the alarm/remote if it simply has the 'oval buttons'. At the end of 01' they changed it to a more square button style.
    4th Gear
    Oct 2009
    Toms River NJ
    3,231
    What part # is on the back of your water logged remote?
    Sep 2008
    Ensenada, BC. Mexico
    486
    AFAIK, you gotta stick to remotes from B5, B5.5 wont work. Good thing that you can use FOB from jetta/golf/beattle, i got my second FOB from a 2000 Jetta and it works just fine.
    Jun 2006
    22
    Quote Originally Posted by DerhsLacidar View Post
    My part # is PA6-GF / GK30
    Why?
    Edit: Sorry wrong number. My part # is HLO 1JO 959 753 F
  7. #6
    4th Gear
    Oct 2009
    Toms River NJ
    3,231
    because I have one with that part # if you are interested. The one I have has the three buttons in an oval shape which was the early version instead of the more current rectangle buttons.
  8. #7
    Jun 2006
    22
    That sounds great! How much and how can i get my hands on it?
  9. #8
    Jan 2005
    Chicagoland
    223
  10. #9
    4th Gear
    Oct 2009
    Toms River NJ
    3,231
    Quote Originally Posted by nc2chi View Post
    PM sent!
  11. #10
    Feb 2008
    KC
    24
    sounds like you got your problem solved, but I used some information I found in thread Everything you need to know about buying a 2nd Switchblade Remote
    and sucessfully got a second remote working for my 98 passat b5. the locksmith in town had the switch blade key and cut and put it in for me.
  12. #11
    Jan 2010
    Finland
    25
    180
    Quote Originally Posted by Yukabron View Post
    Nope, the remotes you can swap all the way around... Currently im having on my b5 the same switchblade key + fob that is on the 2010 VW's...
    Also the same remote works for Transporter, scoda, touareg, audi and golf (those i have tested models from -98 to 2010) so it feels for me that the remotes are "one fits all"
    The thing that cant be changed is the immobilizer, b5 and b5.5 use different immobilizer, so the rfid's inside the key wount crossfit. That can easyly be overcome by opening the blade part of the key (hold together by one small philips screw under the "VW" sticker), from inside you find small "glasspill" that has copper coil inside, thats the "immobilizer's id" take the new one off, and throw your old one in - You got 2010model key on 1998 car
  13. #12
    Jun 2006
    22
    @ Carlos... I thought the VW part number and the FCC Transmitter ID# would have to match. Also, my 99 remote does not have an immobilizer, so does this mean that in theory any key fob could work?
    EDIT: @Lukengruven...okay just answered my questions...thx
  14. #13
    Jan 2010
    Finland
    25
    180
    The immobilizer is in the key, not the remote
    The immobilizer "transmitter" is located in the keypart, only few millimeters away from the actual keyblade...
  15. #14
    Lefties have rights, too!
    Apr 2001
    NY or MA???
    57
    15,622
    There may be some differences betweem Eurpean and NA key remotes. My '99 Passat came with the banjo style remote. I was able to upgrade to a 2000 or 2001 Golf switch blade remote but I believe a B5.5 remote would not work on my '99. I suggest trying to borrow a remote from a friend and try to program it before bying it.
  16. #15
    Jan 2010
    Finland
    25
    180
    Quote Originally Posted by Tom Parish View Post
    i also had the banjo remote key, for me it feld too 80's so wanted to upgrade...
    so went from:
    http://image.ec21.com/image/cnautoke...ponder_Key.jpg
    to
    http://www.bridgat.com/files/vw_tran...mote_key_3.jpg
  17. Remove Advertisements
