Safe to drive with no power steering?
NEWS
Results 1 to 13 of 13
    2nd Gear
    Feb 2006
    boston
    501
    Well it turns out the creaky noise I was getting in my 2001 b5.5 was the steering rack because it went out..power steering fluid flowed from the passanger side wheel well like a leaky faucet. I purchased a replacement rack online from a car with similar miles.
    My question until it comes in or when I need to have it fixed is if it is safe to drive with no power steering especially with no steering fluid. I have heard cases where the steering gear would cease up causing the steering to lock. On top of that would my power steering accessory get too hot while on the assembly belt with no fluid in it? If this is the case I'll have to have it towed to a mechanic when the piece comes in.
    Super (Charged) Moderator, Grinding Gears...gone fishing! ScottPassat2.8's Avatar
    Feb 2005
    Staten Is. NY GLX2.8
    45
    22,618
    you will burn out the PS pump if you haven't already.
    Quick Link MASTER at your service.Forum Moderator.
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    59
    10,125
    No, it's not safe to drive - for you, or for your car's components. Besides, if you have an accident, you don't want to explain to the police or insurance companies why you were driving like that.
    2nd Gear
    Feb 2006
    boston
    501
    Is there a way to tell if I have already burnt out my ps pump?
    5th Gear
    Jan 2001
    D/FW TEXAS...
    5,975
    Quote Originally Posted by scottpassat2.8 View Post
    you will burn out the ps pump if you haven't already.
    x2
  7. #6
    5th Gear
    Jan 2001
    D/FW TEXAS...
    5,975
    Quote Originally Posted by Italianxmna89 View Post
    It will sound like it has no p/s fluid in it even when it does and may not provide any power assistance even when full.
  8. #7
    Dec 2008
    City of Champs
    27
    66
    Wait until the rack comes and fill everything up with fluid and see if the pump makes noise.
    You can't really check it now because you will have air pockets so if you put fluid it now it's going to make noise regardless. Did you drive very long with the pump growling?
  9. #8
    4th Gear
    Sep 2007
    Long Island NY
    3,768
    Hell I drove a lot of cars with no power steering. They used to come from the factory that way LOL.
  10. #9
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    59
    10,125
    Quote Originally Posted by UrbanLegend View Post
    As have I, and while that's nice, it doesn't really have relevance here. The steering geometry and hardware of those cars were designed for non-powered use; the Passat's were not. "Unpowered" power steering is much heavier than regular manual steering. Driving that way is not something I'd do except in an extreme emergency.
  11. #10
    murdered out Jetta, er, B5 Passat mrgreek2002's Avatar
    Sep 2001
    '99 1.8T - Toronto
    32
    11,140
    Do not drive it with no power steering! It's gonna be real hard to do on a Passat!
  12. #11
    Jul 2008
    Chicago
    51
    14,661
    After reassembly, use the proper VW spec power steering fluid. Nothing else.
    After refilling, the pump will growl until all the air is purged from the system. It may take many cycles of turning the steering full left to full right and back again before all the air is worked out.
  13. #12
    2nd Gear
    Feb 2006
    boston
    501
    I've driven it less than a half mile since the rack leaked out all the fluid...
  14. #13
    Jul 2008
    Chicago
    51
    14,661
    You should be fine with that. I've gone much further when my PS line leaked out while on the highway.
  15. Remove Advertisements
