The Easiest Way To Find Vacuum Leak on 1.8T Passat
NEWS
Page 1 of 3 123 LastLast
Results 1 to 30 of 90
    Oct 2008
    Ontario
    80
    What is the best way to find out the source of the leak on 1.8T Passat?
    The car idles funny like it's going to die but drives just fine.
    Thanks!
    Jan 2009
    KW & Toronto
    12
    1,980
    That sounds more like your MAF needs to be replaced.
    Oct 2008
    Ontario
    80
    How do I find out if MAF is bad?
    Jun 2010
    Brownsville, Texas
    25
    235
    It's not hard, just clean it out just incase..
    If it stops acting up then it was the MAF..
    4th Gear
    Aug 2006
    Halifax, NS
    40
    4,235
    Unplug the electrical connectors to it. If the car suddenly idles better, that's probably the culprit.
    I've mentioned before, an easy way to check for vacuum leaks is to take a propane torch and crack the gas valve open a little. As the car idles, run the tip of the torch around the hoses, joins, gaskets, etc... anywhere a leak could be. If the idle suddenly surges, then you've found a leak.
  7. #6
    Oct 2008
    Ontario
    80
    Thanks guys, I'm going to check on the MAF later.
    here's the codes that came up:
    12 Faults Found:
    16840 - EVAP System: Very Small Leak Detected
    ***********P0456 - 001 - Upper Limit Exceeded - Intermittent
    17536 - Fuel Trim: Bank 1 (Mult): System too Lean
    ***********P1128 - 001 - Upper Limit Exceeded
    16555 - Fuel Trim: System Too Lean: Bank 1
    ***********P0171 - 001 - Upper Limit Exceeded
    17519 - Oxygen (Lambda) Sensor Regulation: Bank 1: System too Lean
    ***********P1111 - 002 - Lower Limit Exceeded
    16684 - Random/Multiple Cylinder Misfire Detected
    ***********P0300 - 001 - Upper Limit Exceeded
    16685 - Cylinder 1 Misfire Detected
    ***********P0301 - 001 - Upper Limit Exceeded
    16687 - Cylinder 3 Misfire Detected
    ***********P0303 - 001 - Upper Limit Exceeded
    16688 - Cylinder 4 Misfire Detected
    ***********P0304 - 001 - Upper Limit Exceeded - Intermittent
    16686 - Cylinder 2 Misfire Detected
    ***********P0302 - 001 - Upper Limit Exceeded
    16891 - Idle Control System RPM Higher than Expected.
    ***********P0507 - 001 - Upper Limit Exceeded - Intermittent
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    ***********P1297 - 001 - Upper Limit Exceeded
    17544 - Fuel Trim: Bank 1 (Add): System too Lean
    ***********P1136 - 001 - Upper Limit Exceeded
  8. #7
    Jun 2010
    Woodbridge, VA
    48
    Wow, that's a lot of misfires. When is the last time you changed plugs and wires?
  9. #8
    Oct 2008
    Ontario
    80
    just replaced the plugs last week and coils were done recently. I think the leak is the caused, I just don't know the easiest way to find it. Gonna check the MAF reading now.
  10. #9
    Oct 2008
    Ontario
    80
    So maf seems fine. I unplugged the wire but still idling funny. I keep getting code 17705 check DV thing everytime I cleared the codes, could that be the problem?
  11. #10
    Oct 2008
    Ontario
    80
    Look what I found
    not sure if this is the only leak spot
    now how do I take this off. Does anyone know where to look for the part number? I don't wanna take it apart until I get the replacement part.
  12. #11
    Feb 2010
    Los Angeles
    67
    If I am looking at that picture correctly, I believe that's a crack in your turbo inlet pipe. I had a similar crack and replaced it with one made by forge.
    http://www.ecstuning.com/Volkswagen-.../Turbo_Intake/
    As for taking it apart, follow #11-16 from this post.
    K04 Upgrade/Installation
  13. #12
    Oct 2008
    Ontario
    80
    Did that crack cause yours to idle funny? I'll try to take a better pic
  14. #13
    Feb 2010
    Los Angeles
    67
    I think I didn't have a problem with the idle, but that was because the crack was not as severe as yours looks. Some idle problems can be attributed to vacuum leak. But in my case, the only thing I noticed was the lack of power.
  15. #14
    Oct 2008
    Ontario
    80
  16. #15
    Oct 2008
    Ontario
    80
    Looking at the codes again looks like that is the only leak spot.
  17. #16
    Oct 2008
    Ontario
    80
    Ok so the replacement pipe didn't help. I'm still getting this code that is causing all cylinders misfired.
    Any idea next part I should look into?
    Also in block 002, all last 3 readings seem higher than the limit.
  18. #17
    Jan 2005
    Chicagoland
    216
    You can make your own pressure tester from plumbing PVC at Home Depot or the like. I have one that I made. I also searched and see that there are at least two sites that have a how to for making one. Basically I disconnect my Air box and plug the pressure fitting into that. I don't have the time to type it all right now but you get the hint. Put an air hose on the fitting and turn the compressor up to about 25 psi. Look for any leaks. you'll find them. Unless it's electrical. Good luck.
  19. #18
    Sep 2006
    plano/waco, Tx
    25
    13,316
    Blog Entries
    5
    Quote Originally Posted by Troy Jollimore View Post
    of course, the flame must be off. you're only using the gas.
    Quote Originally Posted by noodles View Post
    those misfires are unrelated to plugs and wires... they're the symptom of whatever is happening...
  20. #19
    Oct 2008
    Ontario
    80
    There is weird noise everytime I shift to reverse or drive, It sounds like when you just open drivers door
    Here's the link to the sound clip.
    http://www.youtube.com/watch?v=AQ2CVvhaass
    LOL
  21. #20
    Overdrive
    Jul 2008
    Chicago
    50
    10,886
    Have you checked the diverter valve? If it's leaking (passing air) you won't catch that with a boost leak tester.
    The noise in the video could be a number of things. One of those things it might be is air passing through a hole/cut/split in a hose and making a humming noise. A ruptured Diverter Valve diaphragm may also hum, but I don't know if you'd get that at idle.
    Best advice so far was the suggestion to make a boost leak tester and see what shows up.
    As for the propane trick, that's something I used to use all the time on older engines. On these newer computer controlled and idle stabilized engine systems, it doesn't work as well. The engine has to be running super lean beyond the ECM's ability to compensate before you see any change in idle. If it isn't that far out of whack, the computer will compensate and when the propane is added, the computer stops compensating. You may not detect any change in idle because the system responds so quickly. So in other words, if the propane trick fails to pinpoint a leak, that does not mean you still don't have a leak. It just means the ECM can compensate for the leak faster than the propane trick can point it out.
  22. #21
    Oct 2008
    Ontario
    80
    No humming when idle. It sounds like when you just unlock and open driver's side door. How do you find out if the dv is bad?
  23. #22
    Jul 2010
    Portland
    6
    Quote Originally Posted by windhys View Post
    I had the same issue, and it turned out to be a bad DV. I have had several of the other codes you mentioned, I will take a closer look at them and let you know what I did to fix.
  24. #23
    Overdrive
    Jul 2008
    Chicago
    50
    10,886
    Pull the valve off the car and see if it holds pressure when you try to blow through it. You should be able to blow hard into either of the large ports with NO air passing through the valve.
    Stick your little finger up the bottom port and push the plunger up off the seat, then close off the small vacuum port with another finger, then release the finger pushing the plunger. The plunger should stay off the seat (valve open) until you release the vacuum.
  25. #24
    Jul 2010
    Portland
    6
    12 Faults Found:
    I had 16840, replacing the gas tank cap fixed it.
    17536/16555 came up because my MAF was dirty. I went and bought some CRC electronics cleaner and cleaned it. Slipped it back in and went away. However, now my MAF is having issues again, so I am replacing it. Found it for under $60 on eBay.
  26. #25
    Oct 2008
    Ontario
    80
    Quote Originally Posted by pootergeek40 View Post
    I tried unplugging the MAF while engine was still running, didn't change the idle.
  27. #26
    Oct 2008
    Ontario
    80
    I'll check the dv tomorrow morning
  28. #27
    Sep 2006
    plano/waco, Tx
    25
    13,316
    Blog Entries
    5
    oh, may want to also check the side mount intercooler... sometimes they can come apart from age.
  29. #28
    4th Gear
    Aug 2006
    Halifax, NS
    40
    4,235
    That's why I didn't say to light the torch, sipes. But then you never can count on people to follow directions properly.
    Light the propane torch and hold it up next to your rubber hoses. Bingo! You've found a leak! *Laugh*
  30. #29
    Oct 2008
    Ontario
    80
    Looks like I'm building a smoke machine. Just checked the DV and it's fine
    any idea other place to look for leak? Oh there is hissing somewhere around oil dip stick. Anything I should look there?
  31. #30
    Oct 2008
    Ontario
    80
    Torch didn't help
  32. Remove Advertisements
There are currently 3 users browsing this thread. (0 members and 3 guests)
