passat v5 2.3 causing a great deal of problems!!!!!!!
NEWS
Results 1 to 3 of 3
    May 2010
    2
    i bought this car at the beging of the year drove like new only 70k on the clock been fully serviced, took it on a blast to blackpool spot on, got back home and the car juderd coft and spluterd topt it up with some more fuel & booked it in for service & mot flew straight threw bloke at garage said car was immaculate for year! great mmmmmmmm
    last week car started to miss fire terribly parked it up untill local mechanic could get me in, took it down he changed the coil pack and leads as thats what he thought it would be low & behold it still miss fired he then sent it away for futher checks who came back with ignition module! changed that, miss fire gone but car is cutting out in mid flow drivin & tick over is erratic when changing gear they shoot up tick over has now droped to the 600mark never ever did anything like this happen b4 all these parts were changed! a total nite mare, took it back down to the gargage plugged it in no errors even tho they took it out and the car cut on them, end of thats it we got palmed off they couldn't find anything wrong, took it to girlfriends dad who an auto electrician who still couldn't find any faults and has been through and tested all differnet bits and bobs, he did reset something to do with fuel as he said it smelt strongly which would co-inside with it gobbling the stuff!! well drove away still a lumpy tick over 30miles of so later CUT OUT while driving a total nitemare when the car was absolutley fantastic b4, its a 2000 model by the way.
    i would be grateful of any help to try solve what could be causing it to cut out since these parts have been changed could something have been knocked anything please help me!!!
    to add to this i touched a wire near the new module and now my bloody air bag lights on and wont go off!!! to add to that i've noticed small amounts of coolant are leaking from some where what a nitemare i'm so unhappy with the car at the minute compared to how i felt only 3weeks ago!! lol
    thanks
    trev
    Akhristov? Hey, that guy owes me money!
    Oct 2009
    King City, CA
    1,027
    Sounds like it's either a throttle body/air intake or fuel problem... Or something else entirely. What do you mean by "tick", the tachometer?
    The misfires were probably caused by the ignition control module, which you already replaced.
    Engine code is AGZ, right?
    May 2010
    2
    sorry but we use the terms "tick over" around our area for the engine revs when stood still i hope that clarifies it a bit better for you.
    i'm not sure on the engine code how will i find that out?
    thanks for the response, trev
  5. Remove Advertisements
