What did you do to your Passat today? - Page 103
NEWS
Like Tree143Likes
Thread: What did you do to your Passat today?
  1. #3061
    Sep 2012
    United States
    91
    I reset my p0171 code and drove around for awhile, hopefully it doesn't come back.
  3. #3062
    2nd Gear
    Mar 2012
    Iowa City, Iowa
    562
    Found out today that the timing belt has never been changed on mine. 110k on the original.
  4. #3063
    Jan 2012
    North East Ohio
    447
    Quote Originally Posted by Dstenersen View Post
    Hah I'd probably stop driving it until I changed it! That's scary.
  5. #3064
    Jun 2009
    ONTARIO '03 1.8T APR
    28
    1,792
    Quote Originally Posted by B5.5Wagon View Post
    The recommended change is only 100k. Its not too far off.
    Well yesterday, I wired up my cruise control from my mfsw to my turn stalk.
    today, i'm going out to buy a b6 steering wheel. (pretty stoked about that)
  6. #3065
    Jan 2012
    North East Ohio
    447
    Many people change it a good bit before 100k because some have had it break around there.
    Me, I'm planning to pull my driver door apart and check solder connections on the lock mechanism.
  7. #3066
    2nd Gear
    Mar 2012
    Iowa City, Iowa
    562
    I found out where the previous owner did all of his maintenance. Turns out, he was given a list of things to replace at 95k miles.
    Here is the list he was given:
    Water pump
    Timing Belt
    tensioners
    pullys
    front and rear brakes and rotors
    both cv boots
    valve cover gaskets
    tires
    air filter
    He declined the maintenance and i bought this car used from a dealer with 96k miles
    Ive already done this stuff without knowing that list:
    Tires
    air filter
    both cv boots and axel
    all brakes and rotors
    I was given this timing belt information yesterday
  8. #3067
    Jan 2012
    North East Ohio
    447
    Well at least now you know. I'd get on it asap that's for sure! If you can do it your self it's not too expensive.
  9. #3068
    Dec 2012
    Ontario, Ca.
    54
    Painted lower spioler, side skirts, and rear valance. Much cleaner look....
  10. #3069
    Dec 2012
    Ontario, Ca.
    54
    uh.. I mean spoiler.
  11. #3070
    Sep 2011
    Canada
    150
    Quote Originally Posted by Hydro-sweep View Post
    What did you use? Been giving this a bit of thought myself....
  12. #3071
    Aug 2012
    Tacoma, WA
    190
    Any pictures? Did you just spray it down and leave it textured or did you sand the plastic smooth? I've always wondered how it would look with the texture, but worried about the paint not quite matching.
  13. #3072
    Aug 2012
    Hamilton, ON, CAaaaa
    110
    Just set surveillance on it. I don't trust my roommate today for some reason.
  14. #3073
    2nd Gear
    Mar 2012
    Iowa City, Iowa
    562
    Found code 0513 in my climatronic today. the information i have only labels it as Gateway... Not sure what that means or how to fix it
  15. #3074
    Dec 2012
    Ontario, Ca.
    54
    Quote Originally Posted by BobbyShaftoe View Post
    Actually I was able to have the body shop that did the work from the accident paint it all for me for the discountd labor rate they give Mercury. All was painted for $500. Turned out really nice. It totally tranformes the front end. It is amazing how much character is lost with the black bottom.
  16. #3075
    4th Gear
    Apr 2005
    In his workshop
    46
    2,958
    Blog Entries
    3
    Today I overwrote my stock ECU copy's EEPROM with a virgin bin file and that FINALLY let me fire her up for the first time since Tuesday of last week. She sounded great except there was a consistent misfire on cylinder one. Normally I would pull plug and look for spark or perhaps oil in plug recess, but cylinder 1 is of course under the SC.
    Turns out the misfire issue was sorted by reseating the injector electrical connector on #1. Job done.
    I then took a turn around the SW Capital beltway tonight on my stock ECU copy. The tuned ECU did not arrive today in the post and since I sorted the misfire, I had to do some distance at speed and recharge the batteries, hers and mine.
    More about my first impressions of SuperCooled30V.
  17. #3076
    2nd Gear
    Apr 2007
    Des Moines, WA
    59
    962
    I've often thought about doing this, but am concerned about durability. It'll be interesting to see how your painted lowers endure road flak.
  18. #3077
    4th Gear
    Apr 2005
    In his workshop
    46
    2,958
    Blog Entries
    3
    Did it have a DTC code, e.g. a P#### number associated?
  19. #3078
    Sep 2011
    Canada
    150
    ah ha. I see. For some reason, i was thinking that you'd re-done it in the black, and I was hoping for a way to do it myslef wiht spray bombs Body shop work is a ways away for me. I'm doing a good stock mechanical restoration on a budget, but little things to make the old girl look good aren't out of the question. I was thinking about rock-guard or some such crap.
  20. #3079
    Sep 2011
    Canada
    150
    Quote Originally Posted by keithwbloom View Post
    jeez, I've been following your build thread... Nice work! At this point, I can only dream....
  21. #3080
    rockin the nasty azz exhaust tips yo!!
    Jan 2009
    Birmingham, Alabama
    23
    1,390
    half of a timing belt job. took my time... wont be able to finish it until Sunday.
  22. #3081
    4th Gear
    Apr 2005
    In his workshop
    46
    2,958
    Blog Entries
    3
    Quote Originally Posted by mrbutterz View Post
    Did you get your sway bar in the rest of the way yet?
  23. #3082
    Dec 2012
    Ontario, Ca.
    54
    Quote Originally Posted by mark_proulx View Post
    I am as well, but I do not think it will be that bad on the front and rear, no more than the flak you get on the painted portions. The sides are what I am curious to see. I will be getting oem mud flaps to mitigate as much of it as I can. I will post pics once it is buttoned up.
  24. #3083
    Aug 2012
    Massachusetts
    302
    Almost 50 degrees here today. Gave her a wash and fresh oil + filter today, good for another 4-5k. Replaced tranny mounts as well while I was under there.
    Maintenance list before she gets chipped this spring is now down to just lower front control arms, front pads + rotors, and a few PCV bits.
  25. #3084
    Overdrive
    Jul 2008
    Chicago
    50
    10,879
    0513 in hexadecimal is 1299 in decimal.
    01299 - Diagnostic Interface for Data Bus (J533)
    01299 - Ross-Tech Wiki
  26. #3085
    4th Gear
    Apr 2005
    In his workshop
    46
    2,958
    Blog Entries
    3
    Please tell me you had to use a lookup calculator for that. If not, your positronic neural network has me in deep nerd envy.
    Sent from AutoGuide.com App
  27. #3086
    Overdrive
    Jul 2008
    Chicago
    50
    10,879
    not tellin'
    Edit: I just had to include one of my favorite jokes
    There are 10 types of people in this world. Those who understand binary, and those who don't.
  28. #3087
    Nov 2012
    Portland
    68
    QUESTION: How do you clean the black plastic trim on the bottom of the B5.5 passat? Mine is grey now and it's irritating me!
  29. #3088
    Sep 2011
    Canada
    150
    Quote Originally Posted by fanderson View Post
    I used some McGuire's stuff this past fall, "back to black" or something..... with mixed results. It made things look nice for about 3 days.... By then, it had attracted so much dust that I figured I should'a saved my time and money. I've been giving some thought to using a spray-on rock guard or something for a more permanent result. On my car, half way through another crappy Alberta winter, my skirting trim has a greyish-brownish greasy film that is really difficult to remove from the plastic. I'd love to hear of a solution.
  30. #3089
    Aug 2012
    Massachusetts
    302
    "Back to Black" is made by Mother's not Meguiars, and I've found that it works quite well. You have to apply it correctly though. Massage it on liberally, let it dry to a haze, then buff it off. If you try and do it in one step like its Armor All it just runs off. The drying and buffing is key. May take a couple applications if it's faded really badly. After that it should last a decent length of time.
    Not sure about removing any kind of greasy film. My plastic skirts just get faded to grey from sun exposure.
  31. #3090
    Sep 2012
    Midwest of Nowhere
    133
    took this out. plugged in resistors. kept suction jet pump in place. dv straight to intake manifold. oh how i love VW vacuum lines, check valves, and one time use clamps.
    mrbutterz likes this.
  32. Remove Advertisements
There are currently 3 users browsing this thread. (0 members and 3 guests)
