How to replace the air filter
NEWS
Results 1 to 19 of 19
    Jul 2009
    Chicago, US
    314
    How easy is it to replace the air filter, do I have to take to a special mechanic for this. I did the last oil change at walmart and they told me that since the air filter is closed, so they are not certified to open that and replace.
    I've got K&N 33-2125 filter, I think its the air filter for engine and not for the cabin, is it right?
    I'm just itching to be Banned
    Jul 2008
    A Cardboard Box
    11,133
    Look up my name, I did a write up on how to install the K&N filter. I will try and find it for you.
    6th Gear
    Feb 2001
    Twopassatistan
    33
    9,022
    Quote Originally Posted by gaanee View Post
    LMAO, that's a new one to me.
    The air filter is definitely a DIY job, there should be a writeup in the Info Base forum. The Passat is a little trickier than most cars, on account of the engineers' treating the engine bay like an East Berlin apartment complex and trying to cram in as much as possible, but it's pretty straightforward and hard to screw up.
    Yes, you got the right K&N filter
    Motel Room Moderator
    May 2006
    Abingdon, MD
    17,079
    Using that logic, are you sure they even performed the oil change correctly?
    Jul 2008
    A Cardboard Box
    11,133
    The Official K&N Air Filter Install Write Up
    Here it is, I tried to make it easy to follow along. Let me know if you have any questions, but it is relatively easy to do.
  7. #6
    Jul 2009
    Chicago, US
    314
    Quote Originally Posted by NEWMAN'SOWN View Post
    Thanks
  8. #7
    Jul 2009
    Chicago, US
    314
    Quote Originally Posted by VAGguy View Post
    The guy told me that they are not certified mechanic and as per walmart policy they are not allowed to replace anything that is closed, he recommended me to take it to firstone for air filter change, and I'm assuming that they did oil change.
  9. #8
    6th Gear
    Feb 2001
    Twopassatistan
    33
    9,022
    I see you have a V6...it's going to look a good bit different, but the fundamentals are the same--same air intake tube removal, same prongs, etc. No messing with heat shielding or anything like that.
  10. #9
    Jul 2009
    Chicago, US
    314
    Quote Originally Posted by ashman78 View Post
    So its the air filter for engine, and not the cabin air filter, right?
  11. #10
    May 2006
    Abingdon, MD
    17,079
    Cabin filter is even easier.
  12. #11
    6th Gear
    Feb 2001
    Twopassatistan
    33
    9,022
    Yes, often they're also called "Air Cleaner" (or "Engine Air Filter") and "Pollen filter" (or "Cabin Filter"), respectively...you may also see Luftfilter and Innenraumfilterfrom German suppliers.
  13. #12
    Jul 2009
    Chicago, US
    314
    Is it DIY, is there any writeup on that?
  14. #13
    Jul 2008
    A Cardboard Box
    11,133
    What year is your car?
  15. #14
    Jul 2009
    Chicago, US
    314
    Its 03 Passat GLX V6.
  16. #15
    Jul 2008
    A Cardboard Box
    11,133
    Ok, remove the large piece of plastic covering the whole engine compartment.
    Put it off to to the side
    On the far left area of where the cover that you had was removed, there will be the air filter.
    remove it and put in the new ne paying close attention to the way the arrows on the side of the filter are facing.
  17. #16
    Aug 2002
    Plano, TX - GLX 5Spd
    1,456
    For 03 MY, once you removed the large plastic cover, you will see the pollen filter on the passenger side (US) close to the windshield. Just pull the plastic retainer upward which hold the filter in the middle edge then remove the old pollen filter. No screw involved.
  18. #17
    Jul 2009
    Chicago, US
    314
    Are there 2 separate air filters, one for the engine and the other for cabin air?
    and if so, your instructions correspond to which one?
  19. #18
    Nov 2009
    Tahoe
    13
    Quote Originally Posted by yrwei52 View Post
    Please re-read the posts.
    OK, sorry about that. Fixed
  20. #19
    Aug 2002
    1,456
    Please re-read the posts. Yes, there are 2 filters discussed here. K&N filter is the air filter for the engine. The pollen filter, where the post #15 and #16 discussed, is for the AC unit and cabin air.
    And the post #18 is for B5 (through production date Sep. 2000) not for B5.5 (from production date Oct. 2000). Your is B5.5.
  21. Remove Advertisements
