I got a p1613 code in my 99 passat 1.8t 5 speed. I think I know whats the p1613 code is all about. I recently swap the ecu because of erratic idle conditions. Well I plugged in the old ecu back and got the code at the front page when vag-com communicates with ecu...well one of the codes was 06001...and later learned that that code is specifically for stick transmission ECU. When I put back the new/used ecu#2 the code from vag-com said 06051...belongs to an ecu made for an auto transmission. So basically the ecu is trying to communicate with the TCU but the stick cars don't have any so It trows a p1613 code. I need to recode the ecu#2 to work with the stick transmission. The problem is that I've been doing some research on subject and have not been able to find all the info necessary to complete this. I have read that you need a password or code but don't know where to get this code. Can someone give me some insides on how to do this step by step. I'm new in the passat world and new with the Vag-com program wich BTW I got the full version. Please help and thanks in advance.
