Car battery slightly tilted
NEWS
Results 1 to 5 of 5
    Dsk
    Dsk is offline
    2nd Gear
    Jul 2004
    White Marsh, Maryand
    556
    I have to replaced my 7yr old battery in my car. I have read here that the Duralast 48L or 94R-DLG were good choices and the one in the car was a Nappa 48. I went with the Duralast 48 DLG from Autozone. It seems to be the exact same dimensions as the one removed but I can't get in to sit flush in battery rack. Is it ok if its tilted by a half inch. I can secure it with a strap but not sure if leaving it tilted back is ok. I have it tiled so the vent in the middle of the battery is on top of the tilt. Thanks
    Nov 2006
    San Bernardino, CA
    29
    2,060
    i don't see any issues with a slight tilt. however keep an eye on it, just in case.
    4th Gear
    Oct 2005
    Galesville Maryland
    3,261
    Just make sure it can't work it's way loose. Check it again in a week.
    4th Gear
    Jan 2004
    Bear, DE.
    37
    3,838
    Did you cut off that metal bracket? It might sit better that way. Only the OEM size and shape fits with that bracket in place. My indy cut off the thing to put an interstate in there.
    Depending on how much the tilt is, not all of the plate(s) may be covered inside with H2S04. Depends on the battery too. Some have more room so you just top off with distilled water a bit higher. That also runs you the risk of overflow.
    Dec 2007
    Roseville, CA
    1,720
    The battery has to sit flat on an even surface. Take the battery out and find out what's causing your problem and reseat properly.
  7. Remove Advertisements
