How to replace blower motor/resistor bank?
NEWS
Results 1 to 5 of 5
    Dec 2006
    104
    OK damnit......
    Theres 4 fan speeds.
    speeds 1-3 dont work... EVER
    speed 4 is the only functioning speed
    The AC compressor kicks in (the little AC light lights up), and the defrost work ONLY when the switch is switched to speeds 1-3. The blower motor doesnt blow air at this time, but the compressor kicks in and gets the freeon chilly.
    When you click it to speed 4, the compressor disengages and the blower motor starts working.
    No fuses in the car are blown
    Ive replaced the control unit (now the lights on the unit work... yay )
    The relay functions as it should, though it follows the AC light on the control unit, only clicking on on speeds 1-3, and clicking off when the switch is in the off position or speed 4.
    I have a short somewhere and its killing me or the resistor bank is bad.
    The cabin air filter leaked until last fall when I replaced the filter and gasket. The climate control system stopped functioning normally long before that.
    Everything else with the car works great but its half apart right now.... What to check? What to replace?
    Dec 2006
    104
    Well I got the resistor bank at the top of the blower motor out, and with it unplugged my problem persists... the fan only blows on speed 4...... I dont get it.
    Any suggestions?
    Bueller..... Bueller?
    Mar 2009
    Germantown, MD
    45
    The resistor pack has to be present and functional for fan Speeds 1-3 to work. The resistor pack reduces the current going to the fan motor (the biggest drop for Speed 1, the least drop for Speed 3). Speed 4 uses full current, so it will still work with the resistor pack either missing or non-functional. Replace the resistor pack with a new one and all fan speeds should work.
    Dec 2006
    104
    damn.... dealer wants $86.00
    Mar 2009
    Germantown, MD
    45
    What's the part number? I'll find it for you cheaper than that.
  7. Remove Advertisements
