how long is too long? driving on a bent rim
NEWS
Results 1 to 15 of 15
    Apr 2007
    Jerseys Finest
    1,196
    last week i went to get a front alignment because i got one my front half axles replaced etc. i also asked them to rotate my tires at the same time. when i went to pick it up - they said the alignment was done but they couldn't rotate my tires because my back driverside rim was bent...and if they put it in the front of my car, id feel it alot more. its holding air & everything but i haven't taken it off to see if i can see any problems with the rim. o yeh its a stock 15in 5 spoke for my 98 passat. mechanic man said i should get it done sooner than later...and the tire "maybe" salvageable etc..blah blah
    this is an excuse for getting some cheap rims BUT my $$ going toward my suspension as we speak ;-)
    how long is too long to drive this way? TIA
    Sep 2006
    Ashburn, VA
    31
    8,987
    Driving on a bent rim at all is too long. Get it fixed before it blows out on the highway at night during a thunderstorm with your whole family in the car.
    4th Gear
    Jul 2007
    3,480
    Is there uneven wear on that tire?
    Probably best not to wait too long but a few more days without uneven wear means you probably aren't doing too much damage to your tire.
    Swap with your (full-size) spare for a couple of weeks until you can get a replacement alloy rim.
    murdered out Jetta, er, B5 Passat mrgreek2002's Avatar
    Sep 2001
    '99 1.8T - Toronto
    32
    11,131
    Get a another rim of the same kind. You can get a used one from a local junk yard. Just search www.car-part.com for one near you. You just refine the search to your car model year, make, model, state or country, and then under part, search for "wheel (with image/picture) and then just check off yours and you should have some luck finding one near by.
    Dec 2007
    Roseville, CA
    1,720
  7. #6
    $t0rm1n n0rm@n
    Mar 2005
    Everywhere!!!!!!!!!!
    34
    8,184
    Now it has been to long
  8. #7
    Resident a-hole knowitall
    Mar 2007
    CT - in racecar
    14
    15,616
    how bent are we talking? can you visible see the bend? if so can you show pics?
  9. #8
    Jan 2003
    Waterford CT USA
    26,851
    Blog Entries
    4
    it all depends on how badly the rim is bent. I'd venture an eeducated guess that a minor bend isn't going to cause a blowout, unless you are driving at a great rate of speed (higher than normal highway speeds) for a prolonged period of time.
    I have one bent right now, and it's presently on the front passenger side. that rim will be on the rear shortly. it is noticeable to ME, but not necessarily to others who might drive my car (my wife, for example). I drive the car 120 miles daily...and it has been bent for at least 6 months.
  10. #9
    Loose female member
    Aug 2001
    Tallahassee
    4,352
    Get it replaced.
    I hit a pot hole 6 months back. Just after that I rotated the tires.
    Noticed a weird shimmy, drove for a few months.
    Rotated tires, noticed a weird vibration, let it go a few months.
    Started to notice a whine from the front end.
    Checked my wheel bearings, both front were shot.
    Checked the rear, one of the rears was shot.
    Checked the rims, forund the bent rim
    Put on a new rim plus bearings all around
    It could have been cheaper.
    Really I should of just checked the rims and replaced the bent one.
    It was not visible on the car, but on a machine you could see the wobble.
  11. #10
    May 2006
    Abingdon, MD
    37
    20,247
    ^ that'll do it.
  12. #11
    Sep 2006
    plano/waco, Tx
    26
    13,315
    Blog Entries
    5
    i've got a bent one. i's noticeable, and is properly sealed now, but i don't know when it happened.
    oddly enough, it was able to balance out, so i'm happy with it, and ignore it.
    i'l be getting rid of my asa set after i get my huffs back from the repair shop getting resurfaced and a minor rim ding fixed.
    got a place around here called "wheel technologies" cutting me a deal through my commercial dept at work (autozone) for $98 and that's the FULL work.
  13. #12
    2nd Gear
    Apr 2006
    baltimore MD
    24
    674
    i have a bent one it hasn't been causing any problems, but recently the guy at sears told me it wouldn't be a problem alignment wise but it may throw the tire wear off a little bit, basically its not a problem except that the mass being a little different would wear the tire differently.
  14. #13
    Jul 2008
    Chicago
    51
    14,354
    Sometimes a bent rim can be repaired. It depends on the rim and the amount of damage. Look around for a place that specializes in this sort of thing. Carson Tire by me does this sort of work.
  15. #14
    6th Gear
    Jun 2006
    Bklyn NYC
    9,403
    cant afford a stock 15"er ... buy one and then start saving for the suspension
  16. #15
    Apr 2007
    Jerseys Finest
    1,196
    yeh well the $$ isnt gone yet and ill be focusing on the rim 1st. Visually the rim & tire look fine but i haven't taken it off to get a view of the rim from the inside. the tire wear looks fine, im not an expert but people did agree with me. ill be taking the tire off soon and taken pics of the inside & outside...to see what people think of it on here
    prior to getting the alignment down before i knew about the bent rim, i didnt notice or hear anything at all, besides it pulling a lil bit bc of the alignment. BUT when they did it and told me they couldn't do the rotation, i have been noticing a sound coming from my back driverside rim. Its hard to describe - but i usually on here it when i make a slow turn into my driveway for example. So i know he took of the wheel & found out it was bent but its funny how i hear this noise now BUT i didnt hear the noise before he took the wheel off.....
    i KNOW shouldn't be driving that much on it but im keepin n eye on it and limiting my driving until i get a full size spare or something similar. sucks because i found my bill for my current tires from around a year ago & i didnt have a bent rim then - or they just didnt tell me. i dont recall hitting and potholes or anything that would have done this....o well im rambling. thanks PW members
  17. Remove Advertisements
