Can a Leaking Exhaust Cause this?
NEWS
Results 1 to 25 of 25
    Jun 2008
    Boston, MA
    1,074
    My flex pipe needs to be changed. I am just wondering if it can cause the codes P2096 and P0441. P0441 says EVAP small leak/no flow condition and P0296 says post catalyst fuel trim system too lean bank 1.
    murdered out Jetta, er, B5 Passat mrgreek2002's Avatar
    Sep 2001
    '99 1.8T - Toronto
    32
    11,131
    When back in '05/'06 when I had a broken stock flex pipe, I never had a CEL or did my car throw any codes. So I say NO.
    2nd Gear
    Feb 2007
    Bristol, CT
    529
    i would also say no because the flex pipe is after the o2 sensors, and theres nothing after it except piping.
    Jun 2008
    Boston, MA
    1,074
    Quote Originally Posted by 98B520vT View Post
    i thought theres one right after the flex pipe...
    Jun 2008
    Boston, MA
    1,074
    any input on what might be the cause of those 2 codes then? possibly anyone with the same codes?
  7. #6
    Dec 2005
    milford ct
    26
    2,370
    nope. my flex section complty blow apart thanks to big turbo setup. and i ran my car like that for like 2months no codes. was loud as shit tho
  8. #7
    Nov 2008
    101
    i thought p0441 was the evap purge valve not working?
  9. #8
    Jun 2008
    Boston, MA
    1,074
    i changed the purge valve already so thats not it. i'm pretty sure its either vacuum hoses leaking or o2 sensor. just want to make sure i know which one it is before i spend a hundred bucks on a damn sensor.
  10. #9
    2nd Gear
    May 2008
    chandler, az
    44
    891
    FInd the vacum leak and that should take care of both of your codes.
  11. #10
    4th Gear
    Oct 2008
    Calgary Alberta
    36
    4,423
    I just pointed this link out yesterday to someone with the same problem. http://www.a4mods.com/index.php?page...tml&category=5 Build it and use it. The only surefire way to test for a leak is to pressure test the system. Don't make the mistake of throwing parts at it. Oh and no, the flexpipe isn't the problem. Like B5.5passat I had the same problem and it never made a difference.
  12. #11
    Jun 2008
    Boston, MA
    1,074
    I decided to go outside and get you guys some pictures. I think I found the mother effer setting off my CEL. And heres a pic of the vacuum hose diagram under the hood for any of you who might want it. What do you guys think? That has to be it right?
  13. #12
    Jan 2009
    Johnson County, KS
    24
    177
    Blog Entries
    1
    i'd just replace the hoses man, honestly it's going to run you a few bucks . i replaced most of mine today and if you replace the hoses you have one less thing to worry about . i got 3 feet of hose for like 2 bucks. if new hoses dont fix it then look at the o2 sensor.
  14. #13
    Sep 2006
    Waterloo, Ontario
    78
    How come I don't have one of those vacuum line stickers under the hood.
    BTW your going to need about 6-8 feet of hose to replace all the lines.
  15. #14
    Jun 2008
    Boston, MA
    1,074
    yeah i changed the hoses already, but its still throwing a CEL
  16. #15
    WF16 Champion and Argumentative Wanker
    May 2005
    In boost :)
    25
    9,018
    Do you have a V6? B/c when my flex section began to leak, my car threw a CEL. Was it related? Don't know, but it could be. Also, it could be the exhaust solenoid. That is an expensive fix, I just had mine done. Fixed my CEL woes.
  17. #16
    Jun 2008
    Boston, MA
    1,074
    Quote Originally Posted by BlueBayou View Post
    agreed, my flex is leaking and it sounds like shit. i'm pretty sure thats the reason. the guy in my area that did it for me messed it up the first time so hes gonna redo it for free, but its so hard to get a hold of him.
  18. #17
    May 2005
    In boost :)
    25
    9,018
    make sure he uses the repair kit...it looks like a very long clamp, but it bends and flexes like it should. Not just welding it back or whatever.
  19. #18
    Jun 2008
    Boston, MA
    1,074
    theres a repair kit???....shit he already did one without using anything. do you think its a big deal?
  20. #19
    May 2005
    In boost :)
    25
    9,018
    Well, I had mine welded once (myself) and it didn't hold. I found a repair kit at NAPA. (surprising, I know) And it's a pretty simple fix after that.
  21. #20
    Jun 2008
    Boston, MA
    1,074
    all he did was cut off the flex pipe that was on there, and he welded a new flex pipe in, i thought it looked fine...whats the repair kit consist of?
  22. #21
    May 2005
    In boost :)
    25
    9,018
    Oh, that's fine. You're prolly all set now, I didn't realize he put in a new flex. That's cool.
  23. #22
    Jun 2008
    Boston, MA
    1,074
    ohh...you scared me for a sec lol. i was thinking that i should expect it to be dead again in a year.
  24. #23
    May 2005
    In boost :)
    25
    9,018
    no, no. you should be okay.
  25. #24
    4th Gear
    Sep 2006
    haverstraw ny
    2,548
    Quote Originally Posted by b5.5passat View Post
    yours is 1.8t and his is v6...
    you dont have the O2 sensor after the flex and he does...
  26. #25
    4th Gear
    Sep 2006
    haverstraw ny
    2,548
    the o2 sensor code, is related to the flex pipe(however usually below threshold code popes up not the lean) but i would go for the flex first...
  27. Remove Advertisements
