Wagon rear hatch door issue
NEWS
Results 1 to 11 of 11
    Nov 2008
    Houston
    42
    My rear hatch door does not pop open a bit when either the Key FOB button is pushed or the driver door lever is pulled up. The hatch is open, however, but it seems like the electrics are not doing what thier supposed to be. I guess there is a solinoid in the mechanism to make the door function as when new.
    I have a 2005 Passat wagon.
    Anyone have a clue? I have a Vag-Com but where (which module or test) would I look to see if it recognizes the issue?
    Thanks,
    Tony
    Jun 2008
    Atlanta
    38
    379
    Might be the micro switch in the hatch. If you open you hatch, does the overhead light come on? If you unlock the car with the remote and open the hatch without opening other doors, does the car lock itself (as if you did not open the door)? If you answered yes to any of the questions, then you have a bad micro switch.
    I don't know where to test with the VAG-COM.
    Feb 2003
    Hamden, CT USA
    41
    2,214
    There's nothing the VAG-COM will come up with in all likelihood, but you can poke around the CCM if you'd like.
    A number of things can fail in there- there's two solenoids. One to lock/unlock, one to latch/unlatch. There's also a microswitch on the latch mechanism that can corrode if your rear windshield washer is leaking (does the nozzle follow the arc of the wiper sometimes? This means the tube has broken internally, and it's leaking inside the compartment.
    Does the light in the trunk work consistently? This is one indicator that the microswitch is failing. It's part of the trunk latch mechanism, so you have to buy both together. Roughly $30.
    Nov 2008
    Houston
    42
    With the doors all locked:
    Using the remote to open the hatch: hatch is lifted, interior light comes on. When I close the hatch, the car re-arms itself (beep, light flash).
    With the key to open the hatch, the same set of events goes on.
    So it looks like a bad micro switch? What is the micro switch controlling? The operation of the solinoid?
    edit:diagram at 1stVW Parts indicates a release solinoid but no micro switch in the door. Would this be what you are saying could be the problem?
    Thanks,
    Tony
    Nov 2008
    Houston
    42
    Looks like I'll take the hatch apart tomorrow and see what I can determine. Thanks folks.
    Tony
  7. #6
    Nov 2008
    Houston
    42
    ctobio: where is the best place to buy the parts for the price you indicated?
    Thanks,
    Tony
  8. #7
    Feb 2003
    Hamden, CT USA
    41
    2,214
    If the lights are operating normally (on when opened, off when closed) then it's probably not the microswitch.
    I'm a bit unclear what's wrong here.
    So, when you press the unlock button on either the fob or the door switch, the door unlocks, and you can release the door when you press the button on the release by the license plate. The hatch itself doesn't move unless you move it. That's normal operation.
  9. #8
    Nov 2008
    Houston
    42
    Quote Originally Posted by ctobio View Post
    Oh! I just got this wagon last week and assumed it (the hatch) worked like my 2002 Golf hatch which popped open a bit when you either hit the release on the Key FOB or lifted the release on the driver's door. So on the Passat, it doesn't do that? It just silently unlocks and you have no motion until you lift the door with the handle above the license plate?
    Tony
  10. #9
    Feb 2003
    Hamden, CT USA
    41
    2,214
    Quote Originally Posted by aja8888 View Post
    Tony
    Yep, that's exactly how mine works. Unless mine was defective from the day I bought it brand new, how I described the operation is how it's supposed to work.
  11. #10
    Nov 2008
    Houston
    42
    Thanks, I was a bit confused on the operation as my only experience was with the Golf.
  12. #11
    Mar 2004
    Toronto, ON, Canada
    2,155
    That's how mine works ....
  13. Remove Advertisements
