Replacing marker turn signal or corner lights
NEWS
Results 1 to 6 of 6
    Nov 2000
    Tampa,FL,USA
    72
    Next to the head light on the driver side I'm replacing the corner light or the turn signal light. There is a fancy looking spring and I don't know where it hooks to? It is attached to the light assembly on the back upper part of the light. I have a 2000 passat and if someone could post a pic of the spring hook to what ever it needs to hook on to that what be LOTS of HELP. I can not use the passenger side light since that spring is missing. The passanger side light is broken so can not use as a reference.
    2nd Gear
    Aug 2001
    San Gabriel, CA
    616
    Quote Originally Posted by PassaTRookie View Post
    I don't have a picture, and I'm too lazy to snap one, but the spring has a white plastic hook that fits into a slot in the sheet metal if I'm not mistaken. Look at the passenger side and it will give you the idea. It's really simple and straight forward.
    murdered out Jetta, er, B5 Passat mrgreek2002's Avatar
    Sep 2001
    '99 1.8T - Toronto
    32
    11,151
    If the passenger side one's spring is broken then it's not safe to have it like that on the car. It could fall off if you hit a bump in the road or a pot hole. Trust me, I lost mine of the freeway when the car was new and I didn't know anything about the car yet. Try a local scrap yard to buy either the spring piece of the whole corner light. From the deal they are around $60+ each.
    Oct 2007
    Toronto, Canada
    226
    the back of the corner light should look like this and the white plastic ring is attached by a spring:
    The white plastic ring-shaped thing should be the one that does the hook up.
    Oct 2007
    Toronto, Canada
    226
    sorry, it's not white in this picture, it's more like grayish...^_^
  7. #6
    Sep 2001
    '99 1.8T - Toronto
    32
    11,151
    This is D.Passat00's pic, but it should give you an idea of the location of where to put that clip into the sheet metal.
  8. Remove Advertisements
