EDL or ASR
NEWS
Results 1 to 23 of 23
Thread: EDL or ASR
    2nd Gear
    Jun 2007
    Ca, North Bay Area
    705
    EDL or ASR
    I know i have ASR in my passat b5.5 2001, but not sure if it's equip with EDL(electronic differential locking). How do I find out?
    Dec 2007
    Estonia
    138
    Check the sticker in your trunk.
    1AH - electronic differential lock (EDL)
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    51
    21,873
    I though EDL was stock on all US FWD Tip Passats. My 2000 1.8T GLS sedan had it.
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    59
    10,121
    Interesting. Doing a little Googleing, sources say all Passats 2000 and later have EDL. But my 2000 GLS doesn't have 1AH anywhere on the sticker. I do have a 1AJ; what's that?
    2nd Gear
    Jun 2007
    Ca, North Bay Area
    705
    Quote Originally Posted by scotts13 View Post
    That is what i am trying to figure out as well. model 2000 gls and up should have it but couldn't find it anywhere on the sticker.
    BTW, what does this do exactly? is this similar to ESR?
  7. #6
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    51
    21,873
    EDL locked the front differential side to side at speeds up to 20MPH. This helps the car pull out on snow/ice and wet conditions.
    Even though my sedan had it, I never noticed it working. The ASR always kicked in when I hit the gas too hard while turning. Looking at the differential, I don't think there are any electronics inside of it anyway. I think it is marketing BS, making the ASR seem like EDL.
  8. #7
    4th Gear
    Nov 2003
    Raleigh, NC
    37
    3,817
    PZ,
    EDL works not by actually doing anything inside the diff. Rather, it uses the ABS system to brake the slipping wheel, which causes the diff to redirect power to the wheel that isn't slipping. (Due to the design of a differential, all power unfortunately goes to the wheel with no traction.)
    ASR adds on to this by cutting power to the engine during wheel slip conditions.
    SirWired
  9. #8
    2nd Gear
    Jun 2007
    Ca, North Bay Area
    705
    cool.
    i will probably stop checking if i have it or not.
    Do you guys think i have it though? I think it would be cool if I have it.
    BTW, I got stuck in snow when getting out from parking lot. my friend had to go out and wiggled the car. in contrary, i mentioned before i drove at night once up hill in a blizzard WITHOUT chain and made it through. I felt the power transferring in front wheel from side to side but it worked.
  10. #9
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    51
    21,873
    Quote Originally Posted by sirwired View Post
    PZ,
    SirWired
    Like I said, it's marketing BS. There is no "lock" involved in the "Electronic Differential Lock".
  11. #10
    4th Gear
    Nov 2003
    Raleigh, NC
    37
    3,817
    But the EDL does lock the differential. It just does so through the brakes instead of the differential case itself. The end effect is the same.
    SirWired
  12. #11
    Resident a-hole knowitall
    Mar 2007
    CT - in racecar
    15
    15,624
    EDL uses the brakes to send power to the other wheel the fact that they call it an electronic locking diff is horse sh!t the diff is open all the time. all it does is slow the spining wheel and let the power go to the other one. there is no diff lock up, its just a normal open diff.
    now if you wanna talk about a real diff that will direct power to both wheels all the time lets talk about a quaife, now there is some real fun. nothing like cruising in the rain in third and getting a little to boost happy and the diff locking up around a corner and both tires start to spin, scared the sh!t out of me the first time it happened, thar guard rail was really really close when i finally got traction again.
  13. #12
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    51
    21,873
    Right, I grew up with RWD Posi on American muscle cars. Both tires spun in the same direction at the same speed. That is a locking differential. Quaife is the same type of differential, but for FWD.
  14. #13
    he just thinks he's amazing. really. no kidding.
    May 2008
    San Jose, CA
    31
    3,780
    Blog Entries
    1
    Quote Originally Posted by vwb5t View Post
    Yea, true, but it isn't marketed as a locking differential. It is marketed as an electronic differential lock. There is no bullshit about it. It uses electronics to calculate wheel spin and apply brakes, creating a locking effect. And I have to admit, the Passat's EDL system is at least twice as good as the mechanical "locking differential" that came in my S10 ZR-2.
    I don't need rain to do that in the Suppie...
    Factory LSD FTW.
  15. #14
    Nov 2004
    Baltimore, MD
    38
    1,848
    All of those.. Quaife, Eaton, etc. are not locking differentials either. They are LIMITED slip.
    The only diffs that truly lock are lockers and spools.
  16. #15
    Mar 2007
    CT - in racecar
    15
    15,624
    Quote Originally Posted by TheAmazingDave View Post
    yes locking affect but no actual locking and no actual diff changes which is why it is horse sh!t, they are just slowing one wheel so the open diff will go to the other side that has less resistance.
  17. #16
    2nd Gear
    Jun 2007
    Ca, North Bay Area
    705
    ok. does that mean i already have this feature? it wouldnt hurt to have it.
  18. #17
    Nov 2004
    Baltimore, MD
    38
    1,848
    Quote Originally Posted by anotherniki View Post
    Based on this statement I would say you probably have EDL.
  19. #18
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    51
    21,873
    Who are you and why are you hijacking this thread?
  20. #19
    4th Gear
    Nov 2005
    Arizona
    3,559
    1AH electronic differential lock (EDL)
    1AJ anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
    EDL is what vwb5t says. It simply transfers torque from one wheel to another. Watch the videos for a good explanation of abs and asr.
  21. #20
    4th Gear
    Nov 2005
    Arizona
    3,559
    Yes, you have it on a 2001. If in doubt, check the optional equipment codes on the sticker in the trunk and you should find 1AJ.
  22. #21
    5th Gear
    Jun 2006
    Plano, TX
    26
    5,260
    I want a real limited slip. Cornering sucks with EDL.
  23. #22
    Mar 2007
    CT - in racecar
    15
    15,624
    Quote Originally Posted by Xyro TR1 View Post
    yes you do a quaife is amazing, the first time it engages on a corner puts a very big smile on your face.
  24. #23
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    51
    21,873
    I no longer have the problem
  25. Remove Advertisements
