How to change tail light bulb
NEWS
Results 1 to 6 of 6
    Jan 2008
    2
    I have performed a search and didn't come up with what I was looking for, so here is my question....
    My left rear taillight bulb is out. I went to my local Pep Boys and they looked up the make/model/year and I bought the bulb they said I needed. But now I can't figure out how to get to wherever the bulb is. Any tips? Or do I just need to bite the bullet and go to the dealership?
    Jan 2008
    2
    Scott-when I click on the link provided, I get the following message:
    "Guest Login
    Enter the e-mail address for the person whose pictures you want to see. For security reasons, you will only be able to see their public pictures. To see a user's private pictures, they must e-mail an invitation to you."
    4th Gear
    Nov 2005
    A house.
    32
    4,346
    Rear Brake Light Bulb replacement-Sedan
    Its the same procedure for the driver's side.. just pull the portion that covers the access to the taillight bulb housing.
    Jan 2011
    Texas
    7
    The drivers side brake bulb replacement on my 03 Passat sedan was a bit harder to access than the passenger side. Due to the rack that holds the emergency kit/owners manual/changer is in the way for trunk access of the circuit board from the trunk. I had to remove the lens assembly (unbolting three nuts) pulling the assembly outwards then unclip the board to access the bulbs. Should have taken photos. Sorry
    Cheers.
  7. #6
    Mar 2008
    SoDak
    12
    Actually, its not much different on the drivers side.
    Actually, its not much different on the drivers side. You need to tear the carpet a little bit at the corners of the flap. The you have just enough room to unclip the bulb holder and access the bulbs.
  8. Remove Advertisements
