Originally Posted by
deusexaethera
It's the cam chain adjuster. Buy a new valve cover gasket and a new CCA gasket, find a reputable shop, and ask them if they can change a chain tensioner gasket on a VW without removing the camshafts. If they say they can't, then they don't know enough about the engine to do a good job in the long run.
After that, make sure to use a 5w40 or 0w40 FULL-SYNTHETIC oil in the engine, and tell the shop to use a 1.9TDI oil filter (it's bigger and holds more oil). DO NOT take your car to Jiffy Lube.
After the shop changes the chain tensioner gasket, if they say the CCA looks like it's in good condition (and if mine at 100kmi was good, then yours better damn well be good), then a couple of runs with the 5w40 or 0w40 synthetic oil should clear up any noise you have. If it doesn't, come back for more advice.
