New brake pads click, advice needed
NEWS
Results 1 to 10 of 10
    Mar 2007
    61
    So I installed new rotors and pads on the front of my 2001.5 Passat. The rotors and pads aren't OEM but are high quality aftermarket. The pads even had the wear sensor built in etc. I've done brakes many times on other cars so I know what I'm doing for the most part.
    However, now that I have installed them, I notice a click sound when I first press the brake pedal. It's not a clunk, it's a click and it only happens once (single click) each time I press the brake pedal at slow speeds. I am fairly certain the sound is the outer brake pads floating up and hitting the caliper or caliper carrier when braking (using up their 2mm or so of play). I did re-install the spring clip, but notice the clip only contacts the caliper and carrier... they do not contact the pads. Unfortunately, I can't remember if the clip is even SUPPOSED to contact the outside of the pads, or if this would even be responsible for the clicking.
    Have any of you experienced the same problem after installing aftermarket pads and if so, what did you do to remedy it?
    Thanks in advance!
    Feb 2004
    West Chester, PA
    36
    1,689
    any news or update?
    2nd Gear
    Apr 2005
    UK
    503
    I bodged mine with folded bits of cardboard, it worked.
    Jul 2006
    Dallas, TX
    38
    342
    Bump.
    I've got this same problem after putting in my pads and rotors. It happened after an incident where I was going about 20 MPH and a car cut in front of me, so I quickly pressed the brake pedal, then sped back up (never stopping)
    Brembo solid rotors and Wagner Thermoquiet pads.
    It is only the front drivers side wheel. It happens as described above, only at slow speeds, only once per brake application.
    I pulled the tires off, pulled of the calipers, bent the clips on the inside pad out a bit to get it to grip the cylinder a bit better.
    Still clicking.
    The brakes perform fine at all speeds.
    Any ideas?
    Since I've got all new rotors and pads, any ideas how much it might cost to have a pro or the dealer figure it out if the board has no ideas?
    the deal finder!
    Feb 2004
    LA, CA
    15,571
    Quote Originally Posted by elton View Post
    i'd be careful...under hard use, the brakes can get really hot...
  7. #6
    Jun 2007
    North West
    31
    cardboard isn't exactly the best material to use, however if it's s a temporary bodge job then I suppose cardboard isn't too bad to use as long as you don't use continuous braking which could lead to the cardboard burning up!...same as D.Passat00 said really...
  8. #7
    Jul 2005
    nor-cal
    2,183
    I've got the same problem, if they're PBR Ultimates just junk them because they're crap. I've tried damn near everything and they still rattle and click all day long.
    It's too bad because the actual compound of them is good, they just don't fit.
  9. #8
    4th Gear
    Jan 2004
    Fayetteville, AR
    26
    2,650
    ^^same here with the ultimates. I'll be going to a porsche caliper soon though, just gives me more reason to complete the kit.
  10. #9
    Mar 2007
    BRONX
    91
    I have the same problem new pads, I had rotors turned, all OEM equipment now a click at low speeds.
  11. #10
    Sep 2006
    plano/waco, Tx
    26
    13,315
    Blog Entries
    5
    Quote Originally Posted by D.Passat00 View Post
    brakes are one of the FEW applications that still use asbestos because of EXACTLY this concern.
    pop your caliper, and remove them now, or you will set them on fire.
    Quote Originally Posted by jkreusc View Post
    Bump.
    Still clicking.
    Any ideas?
    i have exactly this problem as well, currently.
    i just tuned it out, but would love to know what, exactly this is. (also makes noise when you kick it.)
  12. Remove Advertisements
