Service light reset?
NEWS
Results 1 to 16 of 16
    Dec 2005
    New Zealand
    12
    I have a 2001 B5.5 1.8T Passat. I've just done an oil and filter change and I'm now trying to reset the "Service Now" message which appears in the red display in the centre of the instrument cluster when I turn on the ignition. (It clears itself after about ten seconds). To reset this the handbook says "With the ignition off press and hold the trip meter reset button" - (and) - "Turn the knob to reset the minutes on the digital clock to the right."
    "The display will then return to normal."
    I must be missing something here because all that happens with mine is that the trip resets to zero. The "Service Now" message still appears when I turn on the ignition. I've tried it various ways but it makes no difference. (Holding buttons down for ages, doing one before the other, releasing one before the other etc etc.
    Can anyone help? What am I doing wrong?
    Thanks in advance,
    Pugwash.
    Jun 2004
    Denver, Colorado
    177
    Bump... I wanna know too.
    Jun 2005
    Brunei
    36
    61
    Pugwash, the reset button you dealed with is only for trip reset and clock adjustment. To get off the "SERVICE NOW" sign you have to visit a dealer to reset it. They will plug in their com to your car and adjust the next mileage for servicing. Yeah.. its stupid but that the only way how they do bussiness. So visit a VW dealer and PAY!! for problem lost. I HATE VW SERVICE centre but thats the only place where they make you go.
    Jun 2004
    Denver, Colorado
    177
    Does that mean that even VAG-com cannot clear this?
    Dec 2005
    New Zealand
    12
    VW Dealer visit
    Thanks for that. However, it does actually say how to do this in the handbook and these are the instructions which I followed. OK, so I know it didn't work, but why do they put it in the handbook if it doesn't work?
    It's in Section 3.1 (Controls and Equipment) Page 12. (Your handbook maybe different I guess)
    Regards,
    Pugwash.
  7. #6
    I'm Urlik's Hero
    Jul 2004
    UK
    13
    9,784
    You can reset it manually, see this thread for details. We had a good debate about the various methods but it would appear the only one that worked was the one near the end.
    Resetting Service Light
    Hope this helps
    Sam
  8. #7
    stu
    stu is offline
    2nd Gear
    May 2005
    lake district,England.
    625
    hi pugwash.
    i too cannot re-set my service light how it says in the manual.have a look here-http://www.passatworld.com/forums/showthread.php?t=197179
    there seem some that can,some can't
    maybe its my aftermarket sterio?i know they can interfere with diagnostics....just a thought.it seems if you reset the service interval to o,then obvoiusly the car will think it needs a service.i think thats what i must have done.
    heres the manual;
  9. #8
    2nd Gear
    Jun 2005
    SoCaLi-818/661/310/805
    582
    did ya get it?
  10. #9
    Dec 2005
    New Zealand
    12
    Done it!
    Thanks guys. With your help I've managed to reset the "Service Now" light.
    I did this:
    Ignition Off
    Press in and hold trip reset button.
    Turn Ignition On
    Turn clock set button to right
    Let go of clock button and turn ignition off
    Let go of trip button.
    I then turned on the ignition and - no "Service Now" light!
    Yippee!!
    Thanks for all the help.
    Much appreciated.
    Pugwash
    NZ
  11. #10
    2nd Gear
    Jun 2005
    582
    Quote Originally Posted by Pugwash
    I did this:
    Ignition Off
    Turn Ignition On
    Yippee!!
    Much appreciated.
    Pugwash
    NZ
    GREAT! I'm gonna mark this so i can find later:
    nstabl service now light on off no turn wont won't
  12. #11
    Aug 2011
    england
    26
    I have successfully just reset my "OIL" and "INSP" warning on my Passat B5 1.8T 1998 with the following procedure.
    To reset OIL warning:
    1. Shut all doors (I don't know why but it doesn't work with the doors open)
    2. Press and hold "mile reset button"
    3. Turn ignition key on without starting the engine
    4. Release "mile reset button" (OIL will be displayed)
    5. Turn the "clock adjustment button" clockwise
    ---- will be displayed
    JOB DONE!
    To reset INSP warning:
    1. Shut all doors (once again, I don't know why)
    5. Press "mile reset button" once (INSP will be displayed)
    6. Turn the "clock adjustment button" clockwise
    JOB DONE!
    I was successful after a few trial, partly following the Haynes instructions (which do not work)
  13. #12
    Self inflicted facepalm
    May 2007
    SLC
    1,401
    Not to sound like an idiot, but is this on this car and older ones only, non-US spec'd cars? I have an 02 and I have never seen this. Maybe mine is turned off (not that I give a rats ass, I can do my own math).
    Inquiring minds and all that...
  14. #13
    Aug 2002
    Plano, TX - GLX 5Spd
    1,456
    Quote Originally Posted by keithermadness View Post
    Yes, this is for Euro spec'd cars with variable service interval indicator. The service intervals are based on variety of factors in addition to mileage and elapsed time which maximize the lifespan of oil and everything else. These are much better than fixed service intervals used on US Passat's.
  15. #14
    May 2007
    SLC
    1,401
    Quote Originally Posted by yrwei52 View Post
    Yes, this is for Euro spec'd cars with variable service interval indicator. The service intervals are based on variety of factors in addition to mileage and elapsed time which maximize the lifespan of oil and everything else. These are much better than fixed service intervals.
    I think I like my memory and my odometer better.
    Thx for the reply.
  16. #15
    Aug 2002
    1,456
    Thx for the reply.
    You can’t escape it. Many new cars, especially Euro’s, now come with variable service interval indicator. The OCI can be as long as 18,750 miles or 2 years. Of course the oil used needs to meet long-life specifications such as BMW Longlife-04 and VW 504 00.
  17. #16
    May 2007
    SLC
    1,401
    My 2010 A3 has one that can only be turned off by the Dealer...grrr....hope VAG.COM gets it soon!
  18. Remove Advertisements
