What is this CODE P0011???
NEWS
Results 1 to 14 of 14
    Nov 2000
    Tustin Ranch ,California, US
    312
    Is there such a CODE P0011, Tech says no
    I have a code where my cars stalls and the EPC light comes on. It takes a few seconds to key over then it starts up. The code it throughs is P0011, my tech guys says it's an unspecified code and does not show anywhere in his manuals.
    SO IS THERE SUCH A CODE
    the Sal wannabe
    May 2003
    SC'ed grocery getter
    4,903
    from a quick search it seems to be
    P0011 Camshaft Position Actuator A - Bank 1 Timing Over Advanced
    4th Gear
    Jun 2004
    New Port Richey, FL
    27
    2,960
    Need more details on the car...year, model, mileage, V6-1.8T, Chipped?
    Sounds like a faulty camshaft position sensor.
    4th Gear
    Oct 2004
    Encinitas CA
    4,201
    Possibly a bad cam chain adjuster?
    Nov 2000
    312
    Your right on to what I was told before
    2001/ old body
    Motor: AUG
    1.8T
    Not chipped anymore
    Manual
    I was told this from GIAC a while ago when they ran a code on it.
    It has been doing this for a while now.
    Scott
  7. #6
    Nov 2000
    312
    My Tech said he saw in his manual P0010 said camshaft position sensor A then also saw a P0032 Cam shaft Position B.
    Is there more than one Sensor?
    Pain in the ass to fix???
  8. #7
    PassatWorld Staff
    Aug 2001
    Mahtomedi MN USA
    42
    6,165
    P0032 is for the second bank... which you don't have. V6 only.
  9. #8
    Nov 2000
    312
    Dam you people are good,
    So can everybody positivley say there is a such a thing as s P0011?
    Thanks Scott
  10. #9
    Nov 2000
    312
    So is there truely a P0011 code for my car? My tech shows a Cam Position Sensor being P0010... Which is it???
    Please help I need to terll him to fix it or not fix it.
  11. #10
    Nov 2000
    312
    Help anybody? is there such a code for my car??? P0011
  12. #11
    6th Grade
    Feb 2003
    MO
    14,898
    Quote Originally Posted by sashadg
    Yes, there is such a code.
    It is telling you the ECM isn't seeing the required amount of camshaft advance when the ECM operates the solenoid on the cam chain tensioner.
    You can check the resistance of the solenoid itself-it should be 10 to 18 ohms. It will probably test fine that way; it is most likely faulty mechanically, not electrically.
    AUGs are bad about this. Your only recourse is to replace the entire tensioner.
  13. #12
    Nov 2000
    312
    really
    So there is no possible way that the larger injectors are creating the timing issue?
    The car just stalls about 5 minutes after driving it when it's been sitting almost every time. Then it could go for the rest of the day without anything going wrong. Very weird.
    My question is have you heard of this happening before? Car stalls, EPC light comes on, high idle until I restart the car again?
    Thanks Scott
  14. #13
    6th Grade
    Feb 2003
    MO
    14,898
    Thanks Scott
    Those are very unusual symptoms to have in combination with this particular code.
    I don't see a way that that the larger injectors would cause this, but I've been wrong before.
  15. #14
    Feb 2007
    san diego
    341
    Quote Originally Posted by sashadg View Post
    Did you ever fix the problem? Did you have the replace your Cam Chain Tensioner?? I have the same Code(P0011) and also have a 2001 AUG 1.8T w/ 101K mi
    Thanks
    -Josh
  16. Remove Advertisements
