Change Brake Light Bulb in '02 Wagon?
NEWS
Results 1 to 8 of 8
    Jan 2004
    23
    I hate to be stupid, but I just tried changing a brake light bulb in our '02 wagon (driver's side) and couldn't figure it out. Manual is no help ("changing light bulbs has become very complicated - we recommend visiting your authorized VW dealer"... yeah, right).
    Any pointers? Do I have to take the whole taillight lens off to reach the bulb or should I be able to do it from inside the car?
    Thanks and apologies if this is already posted. I did a search and couldn't find the answer.
    Aug 2003
    Arlington, VA 2002 Variant
    73
    This takes slim fingers and patience. Go inside the "wayback" area and remove the access panels (for 1st Aid kit and / or CD changer). You'll be able to access the backs of the light assemblies from there. Find two clips that you can squeeze (roughly at the 9 and 3 o'clock positions), squeeze and pull the assemblies away from the back of the light housing (towards the front of the car).
    You should be able to twist out the old / bad bulb and insert the new / good one. Push the assembly back, make the clips "click", and replace the panel(s).
    May 2004
    Utah, wanting snow
    1,535
    When you go to the way back area take a flashlight, then open the appropriate First Aid/ Changer panel use the flaslinght, and you should be able to figure it out. The manual is way off, these bulbs are a cake walk, dont even need any tools other than a flashlight. Please let us know if you still have problems.
    Nov 2004
    4
    We have a 2002 station wagon also.
    My husband just replaced one of our driver side brake light bulbs. He said that one bulb, the blinker perhaps, had to be removed before the assembly could be pulled into the cd-changer area. With that bulb in the big plastic piece would wiggle when the clips were squeezed but it would not pull out. He also suggested detaching the wire connectors to help twist and turn the assembly in the small space provided. The manual is funny, haha, go to dealer... good idea.
    Thank you.
    May 2002
    LI NY
    322
    Yes, you have to remove the blinker bulb first. You give the grey holder a twist to remove, then you can unclip the main stop / tail / back-up lamp holder.
  7. #6
    4th Gear
    Oct 2004
    Encinitas CA
    4,458
    It is perhaps a bit simpler on the B5 variant, although it is very easy to break one bulb whilst changing another. :oops:
  8. #7
    Jan 2004
    23
    Thanks to all for the advice - I finally got around to it and the tips were very helpful!
  9. #8
    Dec 2004
    00 V6 variant/06 4-m
    61
    2,139
    one of those cheap haynes/chilton manuals w/ pictures too would make that 10 min. job a 5 min. job ,it did for me anyway :wink:
  10. Remove Advertisements
