Add heated windshield washers to B5
NEWS
Results 1 to 5 of 5
    Jul 2002
    Oxford UK
    16
    Doesn't seem to matter how much washer fluid I add to the washer bottle, the fluid still seems to freeze in the nozzles in weather below freezing. It takes a while to thaw before I can wash the windshield.
    Now I hear the later B5.5s have this fixed at last with a washer heating system . Has anyone managed to add this to the B5? Mine is a right hand drive 98 TDI auto wagon (187,000 miles and counting). I can't find any posts from anyone who has fitted the heating system. I have heated mirrors but not seats if this helps.
    Thanks
    Julian
    RAH
    RAH is offline
    5th Gear
    Oct 2003
    Puyallup, WA
    5,743
    I have heated seats and mirrors on mine but never heard of a heated washer system :???: . I want to know as well, so bump for your post
    Forum Moderator
    May 2003
    Dyess AFB, Texas
    39
    23,182
    it's part of the cold weather package. my 99 has heated washers. I don't know how easy the retrofit is since you have to run wiring for the washers.
    Paul
    2nd Gear
    Jul 2003
    Calgary, Alberta
    43
    740
    Yep, our 2000 has them too (I know because I need to replace one of the nozzles - it was flopping around loose when I was looking at it last night and it had a hose and a wire that plugged into it.
    6th Gear
    Jan 2002
    Pittsburgh, PA, USA
    56
    7,580
    Re: Add heated windshield washers to B5
    Quote Originally Posted by sterling
    Thanks
    Julian
    Hey, Julian,
    Exactly how cold does it get in Oxford? I can't believe that your fluid is freezing. The generic washer fluid they sell here in the States is usually marked as good to -20 degrees F (that's almost -30 C), but in reality I've seen it start to crystalize somewhere just south of 0.
    What's the temperature rating on the stuff they sell in the UK? Does it come pre-mixed or is it the stuff you have to dilute and mix yourself? Just curious!
  7. Remove Advertisements
