My Turn signal has stopped working. any ideas?
NEWS
Results 1 to 16 of 16
    Oct 2002
    Rockaway NJ USA
    184
    So today im driving home from work and im trying to merge into traffic. my turn signal is flashing once and then it dies :shock: . i click it again, it flashes once and then dies again. WTF :???: When i got home i tryed the emergency flashers. they dont work either. This Sucks.
    has this ever happened to anyone else? what was the problem? Maybe its the flasher module? Help? :???:
    Apr 2003
    Lake Worth Florida
    272
    most likely the flasher relay, which just so happens to be.....
    The very same 'mergency flasher button you tried
    drumroll, someone give this guy a part # and price pleasie :bow:
    i know, iam a dork...... :weirdo:
    no, really, the flasher relay is the emergency flasher button.
    you just gots to pop it out wit' a couple o butter kanives.
    then take to dealer, and say "I Want This". day hook you up :wink:
    Oct 2002
    Rockaway NJ USA
    184
    So If I replace the Emergency Flasher then my turn signals will work? If i where to take out the button, then none of the flashers would work?
    2nd Gear
    Oct 2003
    Philly area
    666
    Check the fuses before the relay
    Dec 2003
    Elk Grove, CA.
    2,105
    Check the fuses...same thing happened to me last week and i'll i did was replace the fuse, #2 i think, and they worked again!
  7. #6
    Jul 2003
    41
    I had the SAME problem very recently
    http://www.clubb5.com/forums/viewtop...395dae35c77d75
  8. #7
    2nd Gear
    Oct 2002
    Troy MI USA
    39
    774
    ok...here'a dumb question for the guys that got this turn signal is dead problem...
    how in the world that you pop the hazard relay ?? I pull out the hazard button out and that's it....do I have to pull the rest out (the white module in there) ? :???:
    or should I just pay alex a visit and ask her to help me
    thanks in advance,
    C._
  9. #8
    PassatWorld Staff
    Aug 2001
    Mahtomedi MN USA
    44
    6,165
    you need the whole module, not just the button face. There are snaps on each side of the switch. Use one butter knife on each side of the button (as mentioned above) and then pull.
  10. #9
    May 2003
    Aliso Viejo, CA/ Cambridge, MA
    1,513
    Check the hazard buttons connection. If the connection came out, the flashers won't work! Pull out the whole center module, and see if it is connected. If its in there good, then check the fuses. GOOD LUCK!
    Ryan.
  11. #10
    Ray
    Ray is offline
    2nd Gear
    Oct 2003
    San Antonio, Tx
    49
    728
    flasher relay
    If your fusdes are fine yu need to replace the relay on the dashboard. Pry it out and replace it, shouldn't be more than $30.oo at the dealer for the part. Snap it back in place and it should work fine. I replaced mine a while back.
  12. #11
    4th Gear
    May 2001
    Portland, OR
    3,184
    I would suggest pull the radio out first and then you have plenty of room to push the hazzard relay through. The radio just slides out...Do a search for the homemade tool you'll need.
  13. #12
    2nd Gear
    Oct 2002
    Troy MI USA
    39
    774
    finally get the relay out (without pulling my pioneer HU out)....the clips are on the top and bottom and I just pull it out w/ a needlenose pliers.
    for future reference, the part# for the hazard relay:
    3B0 953 235 B
    Thanks to everyone for their input
  14. #13
    Dec 2001
    LA area CA
    1,692
    i have changed mine 2 times so far. They had a differnet part number the second time. Maybe they reworked it. But on the second time before I changed it, I bent the clip that connects to the relay to make it blink and it lasted me another 4-6 months, then finally died....faulty part...$26 for a new one :thumbdow:
  15. #14
    May 2003
    Madison, WI
    31
    I just replaced my hazard relay, or "emergency light switch with relay" (part 3B0 953 235 D) as it is officially called. It was $26.42 shipped from vwparts.com. When installing it in my '98 GLS, I found it easiest to take out the bottom cover (of the 3 vertical button locations. Top being the hazard light, middle the heated seat, and my bottom being just a cover) first.
    Then I pushed up on the heated seat switch, which tilted it so I could pull it out. Then I could push up on the hazard relay assembly in the same fashion and pull it out, pull the wiring off of it, and put on the new relay assembly. It didn't look like it would work to put a butter knife above and below it and slide it out; there are brackets in the way and the fit is too tight. It took less than 5 minutes, once I figured out how to do it.
  16. #15
    Jan 2004
    Delaware, USA
    381
    Don't turn that way so much. You wore it out.
  17. #16
    4th Gear
    Sep 2003
    KS
    4,051
    You could always just stick your arm out the window to signal direction like the ole' days..
  18. Remove Advertisements
