Hello folks
My first proper post here so be gentle with me :thumbup:
I have a 2001 130tdi se estate engine code AWX.
Over the last couple of weeks it has been dropping to 3 cylinders when warm. When cold it is perfect and runs on all 4 cylinders for say the first mile or 2 then when warm will drop to 3 where it shudders badly and feels like its shaking itself apart.
I was told it could be an injector gone down so sourced some second hand ones on e-bay... I thought all the PD injectors were the same but have since found out this not to be the case. The ones I bought were from a Golf Tdi engine code AJM (115bhp?) I have since discovered that the 130 and 150 have different injectors to the 115, can this be confirmed please?
I have also bought a new injector wiring loom as found out these can go bad over time.
Does this symptom sound like an injector issue or a wiring issue?
and
Could anyone confirm if I have bought the wrong injectors or are they interchangable?
Thanks in advance for any info on this
and
