I've been going round and round internet this afternoon and have found this forum so going to post here.....
I have a 2003 Passat TDI Sport.... It has a very soggy back passanger floor... had a mechanic look at it he says it something to do with air filter and it will take him a whole day to fix it (at £14 ph) and needs sorted asap as there are electric components below this and they could be damaged.
So was chatting to a colleague bout this and low and behold she has a 2004 Passat which presented itself with same problem.... her mechanic replaced/ cleaned filter and bored a bung in the undercarriage of her car and no probs ever since and that was 3 years ago.... it cost her bout £20.....
Big difference in prices and I do want the problem sorted asap but don't want to be ripped offf... no idea bout cars and parts etc so need to go to mechanic armed with information or suggestions other than a full days work..... any help greatly appreciated.
It is a blocked pollen filter not an air filter. Its located under the sash on the passangers side. Either that it is the drain holes underneath the battery. Remove the battery and clean the holes and replace the pollen filter and you should be ok. Have you a sunroof??
does recall work still apply to a 11 yr old car?
i have a 2000 glxv6 that i would love to take to a dealer for any little bugs it may have if its under recall
firstly i live in the UK and secondly my car is 2002 so going to a vw dealer who will charge an arm and leg not an option..... i'm hoping to arm myself with enough info on what needs to be done to give to my mechanic to stop him spending an entire day work on the car thus costing a fortune.....
so far i've learnt that it is the pollen filter which either needs replaced or cleaned or possibly the sun roof drains......
where is the bung in my car to drain away the fluid already there????
I have a 2002,and when I first bought it,I had water puddle in the back and front in the passenger side,but I fixed it myself,since there is no recall for pollen filter in here,you will have to take off the plastic cover which have the whipers arms to have access to the pollen filter holder,and when you take it off,clean underneath it very well,and make sure it's very dry,then apply silicon there,they put it back,and everything will be fixed,no more water,and since you are working in that area,clean the drains under the battery and under the servo.
In the passats first after buy you need:
-clean and dry servo/battery area and cut out this plastic drains
-remove polen filter and ecu box, than fix then bac with silicone for oil sump as sanitary one is not suitable as is get damp after some year
-than remove carpet dry all and look at the underbody cups if some of them is missing replace it
-if you have sunroof all drains have to be cleaned
If you do this you have no any problems with water inside. That said ''me'' guy from UK where is raining most time of the year
plus check and clean connections on the pillar just in front of the passenger front door under the glove box it can cause corrossion and cause you all sorts of issues plus the ccm doesnt like water and it is under the carpet in passenger footwell
I have water ingress again its the pollen filter and my local stealership says no recall for it and its a case of replaceing pollen filter housing as well as the seal
but found on here on another thread UKpassats.co.uk • View topic - Pollen Filter Confidential dealer documentation
where this letter seems that vw accept fault to their dealerships
Related Threads
Volkswagen Passat Forum
3M posts
158.6K members
Since 2002
