Does anyone know if there is a way to make my daytime running lights brighter using VAG-COM? I have a 2014 VW Passat TDI SEL Premium with after market HID chinese headlights. They look like the Audi A8 style which has a LED strip for the daytime running lights. They look great except for the LED daytime running light strip. It could be brighter during the day.
I would like the LED daytime running light strip to be brighter during the day and maybe off at night when headlights are on. If anyone can help, I would appreciate it. I have the VAG-COM cable and latest software and I heard somewhere else that it can be done. I just don'k know how.
Light emitting diodes can be made brighter by adding more current to a point but then some point they will burn out or they will fry and you probably don't want to do that because the manufacturer is likely using them at or near their optimum current rating and if they're not bright it's because frankly they just weren't very bright LEDs spec'd during manufacturing
For the newer cars, it's a value "Central Electronics" or "Central Convenience" in VAGCOM. When you're in that section, you go under Adaptation or Coding IIRC. Once you're there, there are a whole bunch of options you can play with, but the brightness of the DRLs is usually set at 80% voltage. You can increase that through the coding.
Just look up "coding central electronics mkv jetta" and you'll get all the guides that are probably applicable to the B7. I've often times found that VAG doesn't change things drastically in terms of electronics.
I will be doing this for someone on their B7 on Wednesday so they can install the HIDs and keep the DRL. Here are the instructions, looks pretty simple: VWVortex.com - HOW-TO: VagCom / VCDS Mods (w/pics)
Did the DRL power adjustment yesterday and it was quite easy even for me (limited computer skills). We also did the same mod for the rear bulbs and added the window and sunroof close to the remote.
Related Threads
Volkswagen Passat Forum
3M posts
158.6K members
Since 2002
