Adding OEM fogs w/ toggle switch? Keyed power source?
NEWS
Results 1 to 8 of 8
    Jan 2013
    D'ville, Georgia
    9
    I just bought a 2012 Passat SE demo model. Car does not have fogs so I ordered the fog light retrofit kit today. I am planning on running them with the factory harness. Instead of having the relay trigger wire run from the headlight switch I want to run a toggle or rocker switch.
    I want the trigger wire to be keyed so it goes off with the ignition. Does anyone know of any wires or a way to do this without having to remove the fuse block or tap into a wire? I am a little afraid of tapping into any wires and risk VW saying I am voiding my warranty or causing any electrical gremlins. Secondly I don't want to run these hot all the time and risk killing a battery because I forgot to turn them off.
    Jan 2013
    D'ville, Georgia
    9
    Any ideas on this? I get the fog kit in tomorrow. Hoping to find some sort of "OEM-ish" looking switch to activate them.
    Jan 2013
    D'ville, Georgia
    9
    Wiring Help
    I am looking to run a toggle switch versus using the factory headlight switch. I assume the red wire runs the power for the lamps. The green/yellow is the trigger wire.
    The black and white that plugs into the BCM is my question. What do those wires do? If I do not plug that into the BCM should I connect the two black/white leads together and will that basically eliminate the headlights high beam fog off function?
    I have a single pole single throw toggle. Power in. Power out. Ground.
    Is there someone who knows if the white/blacks could be used with the toggle. Tape them off. Or just connect them together?
    Wiring diagram in simple man terms would be awesome!! I have a nice clean toggle with red LED light that I plan on using that I think will tie in nicely with the dash.
    Once done I'll post pics of the install if someone can help me with the wiring layout.
    Jan 2012
    Wixom, MI
    24
    42
    Wish I could help, but pics will be required when you figure it out!
    Jan 2013
    D'ville, Georgia
    9
    I know I could just do my own wiring harness but was wanting to use the one I got with the kit. Guess I will be laying them out in the floor with a battery and make some make shift grounds. If I could get a hold of the actual wiring diagram of the harness that might help.
  7. #6
    Forum Sponsor
    Dec 2006
    Wadsworth, OH
    2,371
    Just added our OEM built fog light kit for the B7 to the site!
    Included in this installation kit are the following:
    - Left fog light housing
    - Right fog light housing
    - Left grille insert
    - Right grille insert
    - Fog light retrofit wiring harness
    - Two H8 halogen bulbs
    - All needed retaining hardware
    - European headlight switch with fog light option
    Click here to order.
    Andy
  8. #7
    Jan 2013
    D'ville, Georgia
    9
    Wow. If that's the same kit like VW sells then that is a pretty good deal. I paid $440 for the kit and I bought my Euro switch (OEM VW version) through ECS tuning.
    Love the fog lights!! A definite must for the B7.
  9. #8
    Jan 2013
    D'ville, Georgia
    9
    Just to clarify though I got the kit from another source but the switch through ECS.
  10. Remove Advertisements
